7i77 analog + parallel port Stepgen
- HalaszAttila
- Thank you received: 5
09 Mar 2017 20:28 #89284
by HalaszAttila
7i77 analog + parallel port Stepgen was created by HalaszAttila
Hello,
i have 3 axis milling machine, retrofitted with Linuxcnc + 5i25 + 7i77, with analog servo drives.
Now i want to add separated rotary table. But the table is with stepper motor. Can I add to system one parallel port Step/Dir card, to control the rotary table?
Know Linuxcnc to control analog +/-10V servos together with stepper motor?
- Thank you received: 7488
09 Mar 2017 20:57 #89290
Replied by tommylight on topic 7i77 analog + parallel port Stepgen
Yes and yes, easily. Just need to add the respective values in hal and ini and add loadrt and addf for parallel port in hal.
The following user(s) said Thank You: HalaszAttila
- Thank you received: 5330
09 Mar 2017 21:52 #89297
Replied by PCW on topic 7i77 analog + parallel port Stepgen
You can also use the second 5I25 connector and a simple breakout to get hardware stepgens
The following user(s) said Thank You: HalaszAttila, Tesremos
Time to create page: 3.017 seconds
