- Configuring LinuxCNC
- Advanced Configuration
- Tool change .ngc brakes the ability to use "run from here"
09 Jul 2019 19:35 #138965
by Henk
Replied by Henk on topic Tool change .ngc brakes the ability to use "run from here"
That explains why my lathes don't have that problem. My mill has remapped M6. The lathes not...
09 Jul 2019 20:49 #138969
by Marcking
Replied by Marcking on topic Tool change .ngc brakes the ability to use "run from here"
I made a lathe retrofit weeks ago and worked almost fine, only problem was that I had to add an M01 before each tool change because when running the program with 4 tool changes the program skip the moving blocks and makes the next tool change(very crazy) but with an M01 before each change that worked around ja ja.
10 Jul 2019 14:40 #139005
by Marcking
Found a small workaround which is not really safe but is it the best until now: if I put a block skip symbol( / )in front of each tool change line up to the ones I don't want to use and activating the block skip function I can run from a specific line normally.
I will keep searching mean while.
Time to create page: 0.162 seconds
