- Configuring LinuxCNC
- Advanced Configuration
- Interpreter ignoring axis move commands ina M6 remap 2.8.0-pre1
02 Sep 2020 16:48 #180446
by neller
Replied by neller on topic Interpreter ignoring axis move commands ina M6 remap 2.8.0-pre1
Hi, I am trying to create an automatic tool changer and have the same problems. In python, I control valves and check sensors, then run the g-code, then check the sensors again, and run the g-code again, but it doesn't work in that sequence. For some reason, all the g-code command is executed directly at the end. How did you get around this problem? I am attaching my config. This is an urgent need, please help.
Warning: Spoiler!
#!/usr/bin/python
from interpreter import INTERP_OK
from emccanon import MESSAGE
import hal,linuxcnc, time
linuxcncStat = linuxcnc.stat();
linuxcncCmd = linuxcnc.command()
#Global
fork_offset_y = 20
tool1_x = 10
tool1_y = 100
tool2_x = 20
tool2_y = 100
tool3_x = 30
tool3_y = 100
tool4_x = 40
tool4_y = 100
tool5_x = 50
tool5_y = 100
fork_z = 0
fork_y = 110
safety_z = 10
def func1(self,current_tool):
if current_tool == 1:
self.execute("G0 X%f Y%f" % (tool1_x,tool1_y-fork_offset_y))
elif current_tool == 2:
self.execute("G0 X%f Y%f" % (tool2_x,tool2_y-fork_offset_y))
elif current_tool == 3:
self.execute("G0 X%f Y%f" % (tool3_x,tool3_y-fork_offset_y))
elif current_tool == 4:
self.execute("G0 X%f Y%f" % (tool4_x,tool4_y-fork_offset_y))
elif current_tool == 5:
self.execute("G0 X%f Y%f" % (tool5_x,tool5_y-fork_offset_y))
def func2(self):
self.execute("G0 Z%f" % (fork_z))
def func3(self):
self.execute("G0 Y%f" % (fork_y))
def func4(self):
self.execute("G0 Z%f" % (safety_z))
def func5(self,new_tool):
new_tool_y=0 #Local
if new_tool == 1:
self.execute("G0 X%f Y%f" % (tool1_x,tool1_y))
new_tool_y=tool1_y
elif new_tool == 2:
self.execute("G0 X%f Y%f" % (tool1_x,tool2_y))
new_tool_y=tool2_y
elif new_tool == 3:
self.execute("G0 X%f Y%f" % (tool1_x,tool3_y))
new_tool_y=tool3_y
elif new_tool == 4:
self.execute("G0 X%f Y%f" % (tool1_x,tool4_y))
new_tool_y=tool4_y
elif new_tool == 5:
self.execute("G0 X%f Y%f" % (tool1_x,tool5_y))
new_tool_y=tool5_y
return new_tool_y
def func6(self,new_tool_y):
self.execute("G0 Y%f" % (new_tool_y-fork_offset_y))
def change_prolog_m6(self, **words):
store="hal_neller_changer.input0"
store_sensor="hal_neller_changer.output0"
patron="hal_neller_changer.input1"
patron_sensor="hal_neller_changer.output1"
new_tool=int(hal.get_value("hal_neller_changer.new_tool"))
current_tool=int(hal.get_value("hal_neller_changer.current_tool"))
print("\n")
print("This is m6 prolog")
print("\n")
#self.execute("G0X100")
#self.execute("G0Y100")
#self.execute("G0X0")
#self.execute("G0Y0")
hal.set_p(store,"TRUE") #Open Store
time.sleep(2) #Delay
if hal.get_value(store_sensor):
print("store sensor activated")
#Go to current tool store position
#Z to down (fork)
func2(self)
#Go to fork
func3(self)
hal.set_p(patron,"TRUE") #Open patron
if hal.get_value(patron_sensor):
print("patron sensor activated")
#Z to up (safety position)
func4(self)
#Go to new tool
new_tool_y = func5(self,new_tool)
#Z to down (fork)
func2(self)
hal.set_p(patron,"FALSE") #Close patron
if hal.get_value(patron_sensor)!=True:
func4(self)
else:
print("#Error 03: patron sensor not activated")
else:
print("#Error 02: patron sensor not activated")
else:
print("#Error 01: store sensor not activated")
#Global
fork_offset_y = 20
tool1_x = 10
tool1_y = 100
tool2_x = 20
tool2_y = 100
tool3_x = 30
tool3_y = 100
tool4_x = 40
tool4_y = 100
tool5_x = 50
tool5_y = 100
fork_z = 0
fork_y = 110
safety_z = 10
def func2(self):
def func3(self):
def func4(self):
new_tool_y=0 #Local
if new_tool == 1:
new_tool_y=tool1_y
elif new_tool == 2:
new_tool_y=tool2_y
elif new_tool == 3:
new_tool_y=tool3_y
elif new_tool == 4:
new_tool_y=tool4_y
elif new_tool == 5:
new_tool_y=tool5_y
return new_tool_y
print("\n")
print("\n")
#Z to down (fork)
func2(self)
#Go to fork
func3(self)
func4(self)
#Go to new tool
#Z to down (fork)
func2(self)
func4(self)
else:
else:
else:
02 Sep 2020 17:01 #180448
Replied by andypugh on topic Interpreter ignoring axis move commands ina M6 remap 2.8.0-pre1
Can you put the code in?
The reason I ask is because it is impossible to follow Python code without the indenting, and the spoiler tags seem to have lost that
code tags
The following user(s) said Thank You: neller
02 Sep 2020 17:14 #180450
by neller
#!/usr/bin/python
import hal, linuxcnc, emccanon, time
#Global
fork_offset_y = 20
tool1_x = 10
tool1_y = 100
tool2_x = 20
tool2_y = 100
tool3_x = 30
tool3_y = 100
tool4_x = 40
tool4_y = 100
tool5_x = 50
tool5_y = 100
fork_z = 0
fork_y = 110
safety_z = 10
def func2(self):
def func3(self):
def func4(self):
new_tool_y=0 #Local
if new_tool == 1:
new_tool_y=tool1_y
elif new_tool == 2:
new_tool_y=tool2_y
elif new_tool == 3:
new_tool_y=tool3_y
elif new_tool == 4:
new_tool_y=tool4_y
elif new_tool == 5:
new_tool_y=tool5_y
return new_tool_y
print("\n")
print("\n")
#Z to down (fork)
func2(self)
#Go to fork
func3(self)
func4(self)
#Go to new tool
#Z to down (fork)
func2(self)
func4(self)
else:
else:
else:
02 Sep 2020 17:37 #180451
I only see a few sleep commands, and no wait-for-sensor loops.
I don't think that this is likely to be the problem, but it is an area where an improvement is possible.
It's more clunky in some ways, and less so in others, but controlling the sequence via a G-code routine can work well. G-code has built-in wait-on-input functions which include timeout handling.
There is an example of a G-code tool-change here:
github.com/LinuxCNC/linuxcnc/blob/master...hange/toolchange.ngc
One reason this is potentially useful is that the interpreter does not try to queue moves through a wait-on-input G-code.
It looks like your tool change is all in the prolog code. I am wondering if that is the problem. prolog code is intended to run before the main toolchange sequence and typically just sorts out what need to be done.
Carousel postioning is typically done as part of a remapped T command, and then the change itself as the main M6 remap.
Time to create page: 0.226 seconds
