M6 remap in pure python lessons learned
18 Nov 2021 01:34 #226818
In a pure Python remap you do as you did - code it all in one file.
Replied by cmorley on topic M6 remap in pure python lessons learned
I can't find it in the docs at the moment but I am sure that prolog and epilog are for NGC based remaps only.Another big one that's not documented is that in a pure python remap it cannot run three python scripts in a row. It just wont do it no matter how hard you try.
So, prolog => toolchange => epilog WILL NOT WORK PERIOD...... you put the prolog and epilog in your remap file like in my code and it processes the commands no problem. The way I got it to work is the prolog function is called within the remap and after the toolchange the epilog is built into the end of the remap. This is the only way I could get it to work properly.
18 Nov 2021 10:54 #226852
by bevins
Replied by bevins on topic M6 remap in pure python lessons learned
In the
Remap Extending Gcode
it references stndglue a few times. Once in Section 9 and once in section 9.3. It is very misleading as this is the python sections and you cant use std glue the normal way it was explained in earlier section of the docs. This should be stated in the docs. Otherwise it's a bit misleading and guys are getting stuck there. I've seen it time and time again.
18 Nov 2021 13:11 #226860
Sorry - I don't follow how what I said has anything to do with standardglue?
18 Nov 2021 14:39 #226871
by bevins
Sorry I misinterpreted your response.
Sorry, I assumed we were discussing remapping M6 and the change_prolog and change_epilog is used most of the time in this situation which is in standardglue.Sorry - I don't follow how what I said has anything to do with standardglue?
19 Nov 2021 08:31 #226961
I am discussing m6 remap.
NGC based remaps include python code with - change_prolog and change_epilog entries.
Python only remapping does not.
You can infer the info from here:
linuxcnc.org/docs/devel/html/remap/remap..._the_remap_statement
and here:
linuxcnc.org/docs/devel/html/remap/remap..._option_combinations
Chris
and here:
Chris
- bazhenov4job
30 Nov 2021 14:00 #228010
by bazhenov4job
Replied by bazhenov4job on topic M6 remap in pure python lessons learned
Hi everyone.
Thanks for your replies.
As Bob said the decision is in source files.
My remap now is almost completely consists of calling emccanon functions with poor g-code usage.
I also found a working way to stop interpreter execution using yield expression in python. We also found a way to continue interpreter execution.
The only problem now we have is to move to ender gauge continiously until it becomes corresponding state, like a g38 but in emccanon.
Show you code later.
- bazhenov4job
01 Dec 2021 06:14 #228095
by bazhenov4job
BTW
all operations described in prolog and epiloge sections are homed in pure python routine. Hence former two are unnecessary
- bazhenov4job
17 Dec 2021 12:22 #229286
by bazhenov4job
described all investigation result in
separate topic
Time to create page: 0.213 seconds
