Educate me about estop chains and latches
The first mushroom button, I wired up so it dropped mains power to the 48 volt power supply that drives my stepper motors and enables a pin on my 7i76e.
The next one is a plasma torch breakaway switch which is connected to its own input. So I ored that with the estop signal to iocontrol.
So now I've added a remote pendant that controls a dedicated normally closed estop relay in the control box. This would be ideal if all I had was one pin with a chain of switches for estop but I don't.
It looks like I can create a software estop_latch chain where the outputs feed into the inputs of the next.
So is that how it is meant to work?
Does anyone have an example of multiple estop circuits they can share?
All *mushrooms* always in series NC configuration.
Cheers
Bengt
There has to be a software solution.
- Thank you received: 5925
On servo systems i put 2 sets of limit switches, normal limits and extreeme limits. Normal limits just stop motion and disable drives, extreeme limits shut down all power, just in case everything goes to hell in a basket.
Rod, you should wire the torch and the pendant e-stop to just stop motion and disable drives, e-stops on the machine should cut the power as they are to be used only if something is teribly wrong.
Tommy , thanks. Thats what I have got. One estop on machine drops AC mains power to anything that moves was how I was advised. Initially, the PC was to have been powered from the cabinet so I wanted to keep it alive. but that is not the case anymore so all power could be dropped to the cabinet.
As the build progresses, its got more complicated. So if I tie the torch breakaway and the pendant estop together, what signals do I trigger in LCNC to disable motion and drives? I still have not connected my stepper enable lines but they are 5 volts so I'd need a relay to trigger them.
I think I need to buy a better estop switch so I can add an additional NC mechanism instead of using the cheap one I had in my box of tricks then. I was trying to avoid that as it will just take time to get in.Pendant e-stop is E-STOP and must be in series with the big mushroom!
Merely shutting power to equipment would cause devices to roll to a stop.
LinuxCNC when estop is triggered the drives get disabled and therefore stopping most mechanical motion including spindle rotation. Removing power from an inverter that is driving a spindle would take a few minutes for the spindle to stop instead of using breaking.
When you have requirements for inputs to be in the e-stop chain, energize a relay and place the contacts in series with the e-stop chain. I do this when it is not a safety issue but for mechanical protection like the plasma head falling off.
I never remove power from equipment on an e-stop.
Just my thoughts.
That is why servo systems have e-stop shuting down complete power to moving parts. E-stop is an emergency device and should be treated as such.
