SCARA hand region issues
25 May 2017 13:03 #93615
by Niko
Replied by Niko on topic SCARA hand region issues
Halcompile doesn't allow me to recompile scarakins . The error is something like component must have at least one pin .
Is there a detailed how to ?
I'm not a programmer, so I'm in unknown waters right now .
25 May 2017 16:54 #93624
Replied by andypugh on topic SCARA hand region issues
What halcompile command did you use?
25 May 2017 18:41 #93628
by Niko
Now you mentioned it halcompile --compile should work, right ?
I didn't want to install it for some reason .
29 May 2017 08:29 - 29 May 2017 08:45 #93771
by Niko
The arm extends now . I moved int in manual mode, but I still can't move it in MDI .
I get Linear move on line 0 would exceed Z's negative limit .
P.S. Z only moves down . Jogging + or - doesn't change the direction .
Last edit: 29 May 2017 08:45 by Niko.
29 May 2017 10:12 #93779
If you look at the position in machine coordinates, and command a G53 move of a fraction of a mm do you still get the message?
Is this the same in joint mode?P.S. Z only moves down . Jogging + or - doesn't change the direction .
- Thank you received: 5928
29 May 2017 10:16 #93780
Replied by tommylight on topic SCARA hand region issues
If using 2.8, you have to set the min and max limits in 2 places for each joint and axis.
If using servo motors with loop closed at Linuxcnc, you have to home the axis in some cases or it will not move in one direction when the DRO value is big.
The following user(s) said Thank You: Niko
29 May 2017 10:34 - 29 May 2017 10:43 #93783
by Niko
Andypugh, joint mode is fine, just tried g53 and it doesn't work .
Tommylight, every joint is homed and this regards moving in MDI in world mode .
Jogging in world mode is fine on X and Y but Z is only in one direction .
Last edit: 29 May 2017 10:43 by Niko.
29 May 2017 19:18 #93811
Where does the machine think it is, and how does this compare with the Joint and Axis limits?
If the machine thinks that it is already outside its limits it won't say anything until you try to move. (destinations are checked, but not current position)
30 May 2017 06:25 #93828
by Niko
The square limits are much larger than the hand can reach, something like 2 meters in every direction . Home positions are to the left most position of the joints and it is reflected in the scara gui . Z is 5 mm below the top limit switch .
In 2.7 this setup worked MDI ran fine . There's still a little arc that I'll have to clear up but thats a different topic .
30 May 2017 15:46 #93847
Yes, but, where does the machine _think_ it is in world mode?
