- Configuring LinuxCNC
- Advanced Configuration
- Error: Calling a remapped M6 toolchange from a remapped cycle
- terans1085
- Topic Author
26 Sep 2017 20:56 #99492
by terans1085
Hello,
I am currently in the process of implementing an automatic tool changer to my setup (3 axis router), hence the need to remap M6. I decided to go for an all python approach:
REMAP=M6 modalgroup=6 python=m6
Toolchanging works fine when called from MDI, however an error "Bug: call stack underrun" is happening when a Txx M6 is called from another remapped cycle, also implemented in python:
REMAP=G81.5 modalgroup=1 python=g815
Would you have any insight about this? Thank you for your time
- terans1085
- Topic Author
28 Sep 2017 15:18 #99558
by terans1085
Replied by terans1085 on topic Error: Calling a remapped M6 toolchange from a remapped cycle
So I have decided to rewrite the G81.5 cycle, but this time in gcode, and remapped as G81.4, using the default cycle prolog and epilog. Works perfectly except when an M6 is called, this I'm getting an error as per attached image.
Seems like it is looking for an o<m6> subroutine, but frankly I don't know where to put it given that I have remapped M6 entirely in python.
03 Oct 2017 21:25 #99855
Replied by andypugh on topic Error: Calling a remapped M6 toolchange from a remapped cycle
That is a bit strange. Are you sure that there isn't an ngc=m6 anywhere in your config by mistake?
- terans1085
- Topic Author
04 Oct 2017 04:50 #99893
by terans1085
There is, but it is commented behind #, as all comments go! I will try deleting completely but I have little faith this is the issue
04 Oct 2017 10:08 #99908
Don't bother, commented out is commented out.
You might get a better answer from the Machinekit guys, the chap who wrote the remap code hangs out there now.
It might just be that you can't nest remaps, or that the remapped code needs to be on the top level.
(Perhaps you can call the python part of the remap from G-code as a custom M-code?)
04 Oct 2017 12:44 #99919
by bevins
Replied by bevins on topic Error: Calling a remapped M6 toolchange from a remapped cycle
The interpreter is very finicky when it comes to remapping in python. First it cannot run three python scripts in a row. When it does its read ahead and tries to run a remap inside another remap how will the interpreter get back? I don't think you can do that. It think Michael will tell you the same thing. Not sure.
What happens if you try and add the remap code in the G81.5 remap. Also try just running Tx in the remap and see if the bug is coming from the Tx or the M6. If it is coming from the M6, then you can run the Tx get the selected tool and hard code the toolchange in the G87
Just a thought.
Just a thought.
- terans1085
- Topic Author
10 Oct 2017 05:20 #100134
by terans1085
So what I have done as an interim (possibly permanent) solution is, nest functions rather than remaps.
def m6(self):
if m6func(self) == 1: return INTERP_OK
def m6func(self):
**all m6 code, returning a 1 rather than an INTERP_OK**
Calling m6func(self) directly from the G81.5 remap went well so far. Also I have been reading some of Bevins' threads about his remap. I have not been able to grasp the concept of "yield INTERP_EXECUTE_FINISH", did not notice any difference so far.
Would it be rude if I ask you to have a look at your actual M6 remap python code? as I could not find on the posts.
Thanks a lot for your time!!
def m6(self):
def m6func(self):
10 Oct 2017 22:25 #100168
by bevins
I posted it in another posr last week i think, but i,ll post it here when i get to the shop tonight.
def m6(self):
def m6func(self):
10 Oct 2017 23:48 #100184
by bevins
my remap file. I have an xml class in there, so just blow by that.
I had to change the py extension to .hal so the forum would take it.
The following user(s) said Thank You: terans1085
- terans1085
- Topic Author
18 Oct 2017 16:46 #100516
by terans1085
I have been going through your code, and noticed you use yield INTERP_EXECUTE_FINISH inside function queuebuster(), but never make any call to that. And when I did call, didn't work in my case.
**Might be moving on to something different here, dunno if I should open a new thread....**
I have finally managed to get my remapped M6 somewhat working, BUT, when a gcode file with multiple toolchanges is run, readahead is setting global variables and parameters (from my epilog) way before the next toolchange happens. So if the program is stopped at any point, the machine thinks that the "next" tool is loaded.
Using yield INTERP_EXECUTE_FINISH directly in my remapped m6() produced erratic results, like having linuxcnc open axis.ngc (default).
Any ideas about a workaround??
