M6T Remap
- pmcstoneinc
10 Nov 2017 21:34 - 10 Nov 2017 21:41 #101630
by pmcstoneinc
M6T Remap was created by pmcstoneinc
I do not know where to ask this but looking over doing a complete remap and I noticed that the actual tool pocket parameter does not push the correct value. The value that is being pushed as "pocket" is the table row the tool code resides in in tool.tbl Can anyone else confirm this??? Thanks
Last edit: 10 Nov 2017 21:41 by pmcstoneinc.
- pmcstoneinc
11 Nov 2017 17:20 #101662
by pmcstoneinc
Replied by pmcstoneinc on topic M6T Remap
14 Nov 2017 13:48 #101774
Which version of LinuxCNC? (I thought this had been fixed)
- pmcstoneinc
15 Nov 2017 04:55 #101816
by pmcstoneinc
Thanks Andy you were right def an older version. I have another question in regards to usage of M6 and T When used together on the same line, T or tool prepare info doesn't get pushed until the next usage of M6 Is this related to older version as well??? Let me know. Big thanks.
15 Nov 2017 15:15 #101835
by bevins
Tool prepare should be done before the actual toolchange. Probably whats happening is M6 Tx is doing the toolchange, then setting tool prepare. So your toolchange is using what is in the last toolchange.... When the next M6 comes up it is using the last Tx or what is in the toolprepare bit.
Shouldn't it be Tx M6? Then the M6 would use the new toolprepare......
Thats the way I think it is suppose to be.
- pmcstoneinc
15 Nov 2017 15:21 #101837
by pmcstoneinc
Even using TX M6 first same results as M6 TX.......hmmmm
- pmcstoneinc
15 Nov 2017 15:28 #101841
by pmcstoneinc
It carrys the T, but M6 (remap) doesnt see the updated T if that makes sense......
- pmcstoneinc
15 Nov 2017 15:42 - 15 Nov 2017 15:52 #101844
by pmcstoneinc
o<change> sub
G53G0Z0
G4P0.1
G0 X40 Y-[#<_hal[iocontrol.0.tool-prep-pocket]>*150]
o<change> endsub [1]
m2
using stdglue.py remap for M6, TX is just looped together
G53G0Z0
G4P0.1
m2
Last edit: 15 Nov 2017 15:52 by pmcstoneinc.
Time to create page: 0.150 seconds
