Master - Closed Loop Stepper with XHC-HB04 Jog Issue
- the_canuck
15 Nov 2017 05:24 - 15 Nov 2017 05:26 #101817
by the_canuck
Master - Closed Loop Stepper with XHC-HB04 Jog Issue was created by the_canuck
I'm trying to convert over to 2.8 from 2.7.
I'm having issues with the XHC-HB04 pendant jogging after homed. I'm open to ideas of things to try
Before homed, Jog worked on y axis with single joint. Once homed and in teleop mode jog no longer works with the pendant. z-axis which is not closed loop stepper and has a single servo works just fine not homed or homed.
x-axis is a gantry with 2 servos hence the reason for the 2.8 upgrade. Previously I was slaving the 2 motors with one encoder. Worked okay but I have 2 encoders so 2.8 should improve things I hope as I can run them more independently.
I'm open to ideas as the pendant is a must have as my machine is to big to have to rely on the keyboard at the computer for jogging.
I'm running step/dir DMM-tech servos (which are tuned through the servo drivers and are not connected closed loop to Linuxcnc) through a 5i25 to the standard DMM-tech breakout board. I semi recently added magnetic linear encoders connected through 5i25 with 7i85 breakout. Mechanics are rotating nut ball screws on x and y and normal but high lead ball screw on z.
Here's the hal file:
Here's my ini:
Andrew
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=4 num_pwmgens=1 num_3pwmgens=0 num_stepgens=4 "
setp hm2_5i25.0.pwmgen.pwm_frequency 200
setp hm2_5i25.0.pwmgen.pdm_frequency 3500
setp hm2_5i25.0.watchdog.timeout_ns 10000000
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt charge_pump
loadrt pid names=pid.x,pid.x2,pid.y
addf charge-pump servo-thread
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.x2.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf abs.spindle servo-thread
addf lowpass.spindle servo-thread
addf hm2_5i25.0.write servo-thread
# external output signals
# --- MACHINE-IS-ENABLED ---
setp hm2_5i25.0.gpio.001.is_output true
net machine-is-enabled hm2_5i25.0.gpio.001.out
# --- SPINDLE-ON ---
setp hm2_5i25.0.gpio.005.is_output true
net spindle-on hm2_5i25.0.gpio.005.out
setp hm2_5i25.0.gpio.005.invert_output true
# --- CHARGE-PUMP ---
setp hm2_5i25.0.gpio.007.is_output true
net charge-pump hm2_5i25.0.gpio.007.out
# external input signals
# --- ESTOP-EXT ---
net estop-ext <= hm2_5i25.0.gpio.003.in_not
# --- HOME-X ---
net home-x <= hm2_5i25.0.gpio.013.in_not
# --- HOME-Y ---
net home-y <= hm2_5i25.0.gpio.014.in_not
# --- HOME-Z ---
net home-z <= hm2_5i25.0.gpio.015.in_not
# AXIS X
# Joint 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-output => pid.x.output
net x-pos-cmd => pid.x.command
net x-vel-fb => pid.x.feedback-deriv
net x-pos-fb => pid.x.feedback
# Step Gen signals/setup
setp hm2_5i25.0.stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp hm2_5i25.0.stepgen.00.dirhold [JOINT_0]DIRHOLD
setp hm2_5i25.0.stepgen.00.steplen [JOINT_0]STEPLEN
setp hm2_5i25.0.stepgen.00.stepspace [JOINT_0]STEPSPACE
setp hm2_5i25.0.stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp hm2_5i25.0.stepgen.00.step_type 0
# 0 - for open loop, 1 for pid
setp hm2_5i25.0.stepgen.00.control-type 1
setp hm2_5i25.0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd joint.0.motor-pos-cmd
net x-output => hm2_5i25.0.stepgen.00.velocity-cmd
net x-enable joint.0.amp-enable-out => hm2_5i25.0.stepgen.00.enable
setp hm2_5i25.0.encoder.03.counter-mode 0
setp hm2_5i25.0.encoder.03.filter 1
setp hm2_5i25.0.encoder.03.index-invert 0
setp hm2_5i25.0.encoder.03.index-mask 0
setp hm2_5i25.0.encoder.03.index-mask-invert 0
setp hm2_5i25.0.encoder.03.scale [JOINT_0]ENCODER_SCALE
net x-pos-fb <= hm2_5i25.0.encoder.03.position
net x-vel-fb <= hm2_5i25.0.encoder.03.velocity
net x-pos-fb => joint.0.motor-pos-fb
net x-index-enable joint.0.index-enable <=> hm2_5i25.0.encoder.03.index-enable
net x-pos-rawcounts <= hm2_5i25.0.encoder.03.rawcounts
# ---setup home / limit switch signals---
net home-x => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# Joint 3
setp pid.x2.Pgain [JOINT_3]P
setp pid.x2.Igain [JOINT_3]I
setp pid.x2.Dgain [JOINT_3]D
setp pid.x2.bias [JOINT_3]BIAS
setp pid.x2.FF0 [JOINT_3]FF0
setp pid.x2.FF1 [JOINT_3]FF1
setp pid.x2.FF2 [JOINT_3]FF2
setp pid.x2.deadband [JOINT_3]DEADBAND
setp pid.x2.maxoutput [JOINT_3]MAX_OUTPUT
net x2-index-enable <=> pid.x2.index-enable
net x2-enable => pid.x2.enable
net x2-output => pid.x2.output
net x2-pos-cmd => pid.x2.command
net x2-vel-fb => pid.x2.feedback-deriv
net x2-pos-fb => pid.x2.feedback
setp hm2_5i25.0.stepgen.03.dirsetup [JOINT_3]DIRSETUP
setp hm2_5i25.0.stepgen.03.dirhold [JOINT_3]DIRHOLD
setp hm2_5i25.0.stepgen.03.steplen [JOINT_3]STEPLEN
setp hm2_5i25.0.stepgen.03.stepspace [JOINT_3]STEPSPACE
setp hm2_5i25.0.stepgen.03.position-scale [JOINT_3]STEP_SCALE
setp hm2_5i25.0.stepgen.03.step_type 0
setp hm2_5i25.0.stepgen.03.control-type 1
setp hm2_5i25.0.stepgen.03.maxaccel [JOINT_3]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.03.maxvel [JOINT_3]STEPGEN_MAXVEL
net x2-pos-cmd joint.3.motor-pos-cmd
net x2-output => hm2_5i25.0.stepgen.03.velocity-cmd
net x2-enable joint.3.amp-enable-out => hm2_5i25.0.stepgen.03.enable
setp hm2_5i25.0.encoder.00.counter-mode 0
setp hm2_5i25.0.encoder.00.filter 1
setp hm2_5i25.0.encoder.00.index-invert 0
setp hm2_5i25.0.encoder.00.index-mask 0
setp hm2_5i25.0.encoder.00.index-mask-invert 0
setp hm2_5i25.0.encoder.00.scale [JOINT_3]ENCODER_SCALE
net x2-pos-fb <= hm2_5i25.0.encoder.00.position
net x2-vel-fb <= hm2_5i25.0.encoder.00.velocity
net x2-pos-fb => joint.3.motor-pos-fb
net x2-index-enable joint.3.index-enable <=> hm2_5i25.0.encoder.00.index-enable
net x2-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
net home-x => joint.3.home-sw-in
net x2-neg-limit => joint.3.neg-lim-sw-in
net x2-pos-limit => joint.3.pos-lim-sw-in
# AXIS Y
# Joint 1
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-output => pid.y.output
net y-pos-cmd => pid.y.command
net y-vel-fb => pid.y.feedback-deriv
net y-pos-fb => pid.y.feedback
setp hm2_5i25.0.stepgen.01.dirsetup [JOINT_1]DIRSETUP
setp hm2_5i25.0.stepgen.01.dirhold [JOINT_1]DIRHOLD
setp hm2_5i25.0.stepgen.01.steplen [JOINT_1]STEPLEN
setp hm2_5i25.0.stepgen.01.stepspace [JOINT_1]STEPSPACE
setp hm2_5i25.0.stepgen.01.position-scale [JOINT_1]STEP_SCALE
setp hm2_5i25.0.stepgen.01.step_type 0
# 0-open loop, 1-pid
setp hm2_5i25.0.stepgen.01.control-type 1
setp hm2_5i25.0.stepgen.01.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.01.maxvel [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd joint.1.motor-pos-cmd
net y-output => hm2_5i25.0.stepgen.01.velocity-cmd
net y-enable joint.1.amp-enable-out => hm2_5i25.0.stepgen.01.enable
setp hm2_5i25.0.encoder.01.counter-mode 0
setp hm2_5i25.0.encoder.01.filter 1
setp hm2_5i25.0.encoder.01.index-invert 0
setp hm2_5i25.0.encoder.01.index-mask 0
setp hm2_5i25.0.encoder.01.index-mask-invert 0
setp hm2_5i25.0.encoder.01.scale [JOINT_1]ENCODER_SCALE
net y-pos-fb <= hm2_5i25.0.encoder.01.position
net y-vel-fb <= hm2_5i25.0.encoder.01.velocity
net y-pos-fb => joint.1.motor-pos-fb
net y-index-enable joint.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable
net y-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts
net home-y => joint.1.home-sw-in
net y-neg-limit => joint.1.neg-lim-sw-in
net y-pos-limit => joint.1.pos-lim-sw-in
# AXIS Z
# Joint 2
setp hm2_5i25.0.stepgen.02.dirsetup [JOINT_2]DIRSETUP
setp hm2_5i25.0.stepgen.02.dirhold [JOINT_2]DIRHOLD
setp hm2_5i25.0.stepgen.02.steplen [JOINT_2]STEPLEN
setp hm2_5i25.0.stepgen.02.stepspace [JOINT_2]STEPSPACE
setp hm2_5i25.0.stepgen.02.position-scale [JOINT_2]STEP_SCALE
setp hm2_5i25.0.stepgen.02.step_type 0
setp hm2_5i25.0.stepgen.02.control-type 0
setp hm2_5i25.0.stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL
setp hm2_5i25.0.gpio.009.invert_output true
net z-pos-fb joint.2.motor-pos-fb <= hm2_5i25.0.stepgen.02.position-fb
net z-pos-cmd joint.2.motor-pos-cmd => hm2_5i25.0.stepgen.02.position-cmd
net z-enable joint.2.amp-enable-out => hm2_5i25.0.stepgen.02.enable
net home-z => joint.2.home-sw-in
net z-neg-limit => joint.2.neg-lim-sw-in
net z-pos-limit => joint.2.pos-lim-sw-in
# SPINDLE S
# ---PWM Generator signals/setup---
setp hm2_5i25.0.pwmgen.00.output-type 1
setp hm2_5i25.0.pwmgen.00.scale [SPINDLE_9]OUTPUT_SCALE
net spindle-vel-cmd => hm2_5i25.0.pwmgen.00.value
net machine-is-enabled => hm2_5i25.0.pwmgen.00.enable
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-on <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
#net spindle-ccw <= motion.spindle-reverse
#net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.axis.x.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net joint-select-b halui.axis.y.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net joint-select-c halui.axis.z.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---charge pump signals---
net spindle-on => charge-pump.enable
net charge-pump <= charge-pump.out
# ---coolant signals---
#net coolant-mist <= iocontrol.0.coolant-mist
#net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
#net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-ext => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
Here's my ini:
VERSION = 1.0
MACHINE = HD_Metal_Monster_Mesa_2
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.100000
INTRO_TIME = 2
PROGRAM_PREFIX = /home/canuck/linuxcnc/nc_files
PYVCP = pyvcp-panel.xml
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 2.500000
MAX_LINEAR_VELOCITY = 8.333333
MIN_LINEAR_VELOCITY = 0.016667
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 300000
# SERVO_PERIOD = 800000
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[HAL]
HALFILE = HD_Metal_Monster_Mesa_2.hal
POSTGUI_HALFILE = postgui_call_list.hal
HALFILE = LIB:xhc-hb04.tcl
HALUI = halui
[KINS]
KINEMATICS = trivkins coordinates=XYZX
JOINTS = 4
[TRAJ]
COORDINATES = XYZX
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 1.67
MAX_LINEAR_VELOCITY = 16.67
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_X]
MIN_LIMIT = -0.01
MAX_LIMIT = 72.0
MAX_VELOCITY = 8.33333
MAX_ACCELERATION = 10
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 1.001
STEPGEN_MAXVEL = 20
STEPGEN_MAXACCEL = 10000
BACKLASH = 0
#Velocity Mode PID
P = 40
I = 0
D = 0
FF0 = 0
FF1 = 0.81
FF2 = 0.003
BIAS = 0
DEADBAND = 4e-05
MAX_OUTPUT = 0
ENCODER_SCALE = -25400
# these are in nanoseconds
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
#STEP_SCALE = 10185.92
STEP_SCALE = 10337.8
MIN_LIMIT = -0.01
MAX_LIMIT = 72.0
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = -1.0000
HOME_LATCH_VEL = -0.020000
HOME_SEQUENCE = -1
#HOME_OFFSET = 0.0
#HOME_SEARCH_VEL = 0.0
#HOME_LATCH_VEL = 0.0
#HOME_SEQUENCE = 0
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 1.001
STEPGEN_MAXVEL = 20
BACKLASH = 0
#Velocity Mode PID
P = 40
I = 0
D = 0
FF0 = 0
FF1 = 0.81
FF2 = 0.003
BIAS = 0
DEADBAND = 4e-05
MAX_OUTPUT = 0
ENCODER_SCALE = 25400
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
MIN_LIMIT = -0.01
MAX_LIMIT = 72.0
HOME_OFFSET = 0.0
HOME_SEQUENCE = -1
#HOME_OFFSET = 0.0
#HOME_SEQUENCE = 0
# Axis Y
[AXIS_Y]
MIN_LIMIT = -0.01
MAX_LIMIT = 25
MAX_VELOCITY = 8.333333
MAX_ACCELERATION = 20
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 1.001
STEPGEN_MAXVEL = 20
BACKLASH = 0
P = 90
I = 0
D = 0
FF0 = 0
FF1 = 0.81
FF2 = 0.0035
BIAS = 0
DEADBAND = 4e-05
MAX_OUTPUT = 0
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
MIN_LIMIT = -0.01
MAX_LIMIT = 25.0
HOME_OFFSET = 0.0
HOME_SEQUENCE = 2
# Axis Z
[AXIS_Z]
MIN_LIMIT = -5.9
MAX_LIMIT = 0.01
MAX_VELOCITY = 1.2
MAX_ACCELERATION = 5.0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.05
MIN_FERROR = 0.001
MAX_VELOCITY = 1.2
STEPGEN_MAXVEL = 1.5
STEPGEN_MAXACCEL = 6.2
DIRSETUP = 1000
DIRHOLD = 20000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 25000
MIN_LIMIT = -5.9
MAX_LIMIT = 0.01
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0.500000
HOME_LATCH_VEL = 0.020000
HOME_SEQUENCE = 0
[XHC_HB04_CONFIG]
# specify layout = n for xhc-hb04-layout{n}.cfg files
layout = 1
# coords: specify 4 letters
# coords: switch labels are xyza but any unique 4 letters
# from the set {xyxabcuvw) can be used (if the coord exists)
coords = x y z
# lowpass settings:
# coef: slows rate of change of output, range: 0 < coef < 1
coefs = 1 1 1
# mpg_accels: provision for reduced acceleration for manual mode jogging
mpg_accels = 2 2 20
# scale plus or minus, rotaries may require larger scale factor:
scales = 1 1 1
# jogmode normal(default) or vnormal or plus-minus
jogmode = normal
# sequence 1: 0.001,0.010,0.100,1.000 (mm-based machine)
# sequence 2: 0.001,0.005,0.010,0.020 (inch-based machine)
sequence = 2
# require_pendant = no: create xhc-hb04 hal pins when pendant not connected at startup
# inch_or_mm = in | mm
inch_or_mm = in
[APPLICATIONS]
APP = monitor-xhc-hb04
[XHC_HB04_BUTTONS]
# use button names according to layout file xhc-hb04-layout{n}.cfg
# note: "start-pause" is connected for standard behavior
# controlling halui.pause/halui.resume/halui.run
# these are examples, edit as required:
stop = halui.program.stop
start-pause = std_start_pause
rewind = halui.program.step
safe-z = halui.mdi-command-01
# in this sim, home-all only works first time, hold down till finished:
home = halui.home-all
x2 = halui.mdi-command-02
y2 = halui.mdi-command-03
# probe-input for simulating a probe:
probe-z = motion.probe-input
x0 = halui.mdi-command-04
y0 = halui.mdi-command-05
z0 = halui.mdi-command-06
goto-zero = halui.mdi-command-00
# synthesized per-axis buttons for goto-zero button:
goto-zero-x = ""
goto-zero-y = ""
goto-zero-z = ""
goto-zero-a = ""
step = xhc-hb04.stepsize-up
mode = ""
spindle = halui.mdi-command-07
reset = halui.estop.activate
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HALUI]
# a halui hal pin is created for each MDI_COMMAND below
# halui.mdi-command-00, halui.mdi-command-01,... etc
MDI_COMMAND=G0 X0 Y0 Z0
MDI_COMMAND=G0 Z0
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
MDI_COMMAND=
# Spindle
[SPINDLE_9]
OUTPUT_SCALE = 24000
Andrew
Last edit: 15 Nov 2017 05:26 by the_canuck.
15 Nov 2017 15:16 - 15 Nov 2017 17:00 #101836
by dgarrett
Replied by dgarrett on topic Master - Closed Loop Stepper with XHC-HB04 Jog Issue
For the master branch with joints-axes updates (2.8~pre),
xhc-hb04.tcl handles basic identity kins machines but may
require user intervention for configs that use multiple
joints for a single axis letter.
I adapted your ini file to a sim config by replacing your
machine-dependent halfiles with [HAL]HALFILE=LIB:basic_sim.tcl
and commented-out unprovided and unrelated files
pyvcp-panel.xml,postgui_call_list.hal. I set the sim config
for immediate homing on all joints and specified
kinstype=BOTH for clarity.
Using this config, i found a bug due to a recent commit
(232d7daa3 Wed Nov 8) and pushed a fix (ba44943f9 Wed Nov
15)
With this update, the sim example (xhctest.ini ATTACHED) reproducing
your config works as expected.
So, if you were trying a recent build of the master branch,
you should 1) update to current commit (ba44943f9 or
later), 2) try the attached sim. If this sim works, i
suspect your config can work too (with proper home switch
setup).
15)
setup).
Last edit: 15 Nov 2017 17:00 by dgarrett.
- the_canuck
15 Nov 2017 16:53 - 15 Nov 2017 16:54 #101854
by the_canuck
Replied by the_canuck on topic Master - Closed Loop Stepper with XHC-HB04 Jog Issue
Thanks for checking out my situation.
I'll update the commit tonight and give it a retry.
Been fighting this for a couple days. I assumed it was something in my hal that was incorrect. Forced me to read up on the documentation so not completely unfruitful as I did learn quite a bit.
On homing: My dual joint x axis gantry only has one home switch. I think I found a way to make it work for now without adding a second switch. I'm relying on the gantry to be stiff enough to keep the motors in aligned on first power up and then through home sequence. 2 switches would be a better choice of course and ensure x and y return to perpendicular during homing. I will most likely add the missing switch soon.
Andrew
Andrew
Last edit: 15 Nov 2017 16:54 by the_canuck.
- the_canuck
16 Nov 2017 00:36 #101870
by the_canuck
Confirmed. Issue solved. Jog on the pendant now works correctly!
Nice catch on the int vs float math.
Andrew
Andrew
17 Mar 2018 15:33 #107468
by OT-CNC
Replied by OT-CNC on topic Master - Closed Loop Stepper with XHC-HB04 Jog Issue
I was wondering what linear encoders you are using and how well are they working? Sorry for going off topic here...
"I'm running step/dir DMM-tech servos (which are tuned through the servo drivers and are not connected closed loop to Linuxcnc) through a 5i25 to the standard DMM-tech breakout board. I semi recently added magnetic linear encoders connected through 5i25 with 7i85 breakout. Mechanics are rotating nut ball screws on x and y and normal but high lead ball screw on z"
Time to create page: 0.111 seconds
