Diagnostic procedure for coordinated motion (threading)
24 Nov 2017 19:31 #102310
by sliptonic
Diagnostic procedure for coordinated motion (threading) was created by sliptonic
I've been converting a little Spectralight lathe for our hackerspace and have it mostly working now.
I'm running 2.7.11 uspace with gmoccapy and the Lathe Macros.
Most everything seems to be working perfectly except the threading macro. It works but the resulting threads are terrible. It's almost like multi-start threads. If I set the pitch to 1.5mm, I get multiple threads in that space.
My first guess is that I have something wrong with the index signal but I'm not sure how to diagnose or isolate the problem. I believe the encoder has 200 lines so it should have plenty of resolution.
I roughly tested for backlash by jogging the Z axis and measuring with a digital caliper. It's not great but not bad enough to account for the problem.
My config is here . The current commit is still my Machinekit version. I've converted it to LinuxCNC but haven't pushed yet. relevant hal and .ini file sections are unchanged though.
24 Nov 2017 20:57 #102318
Replied by PCW on topic Diagnostic procedure for coordinated motion (threading)
Is your encoder 200 or 2000 lines? ( the ini file suggests 2000 )
To test coordinated moves i would manually set index enable and make sure that its
1. Cleared at only one location of the spindle
2. That the spindle position advances by 1.000 for each forward turn of the chuck
You can set index enable without changing the hal file by "setsing" the signal that conveys index enable:
halcmd sets spindle-index-enable true
and watch it with halmeter
halmeter signal spindle-index-enable
24 Nov 2017 23:47 #102321
by sliptonic
Replied by sliptonic on topic Diagnostic procedure for coordinated motion (threading)
Hmm. Well, it's certainly not a 2000 line encoder, but this is a clue.
The encoder isn't directly on the spindle, it's on a belt driven pulley. I think a 1:4 ratio. So the index clears 4 times per spindle revolution. With the scale at 8000, I get one spindle revolution counted per physical revolution.
25 Nov 2017 00:17 #102323
OK so the scale is correct but the index is not
LinuxCNC expects only one index event per spindle rotation so
if you try to thread you will get random 90 degree offsets (1/4 thread pitch) in the start of the thread
It might be that the simplest fix is to ignore the encoder index and add a proximity switch on the spindle
for a 1 per turn index
The following user(s) said Thank You: sliptonic
Time to create page: 0.069 seconds
