Temperature Control
20 Mar 2018 17:22 #107629
Replied by andypugh on topic Temperature Control
M109 is in the range of user-M codes so you could create it.
Without using an _actual_ M109 you would typically use an M66 "wait on input"
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m66
I am not 100% sure what an M66 with an analogue input actually does. I think I would set up a comparator in HAL (looking at the PID error output pin) to judge when the setpoint was hit.
20 Mar 2018 17:36 #107630
by B9T
Replied by B9T on topic Temperature Control
M109 is just what I know the "set and wait for temperature" command from 3D printing as. I don't care if I'll either replace it inline with a set of other codes or write a quick pre/postprocessor between the slicer and linuxcnc
That link says:
"Mode 0: IMMEDIATE - no waiting, returns immediately. The current value of the input is stored in parameter #5399"
and
"Mode 0 is the only one permitted for an analog input. "
So I don't think directly waiting for an analog signal is the way to go, especially because that value will require a mapping between value and the actual temperature...
Though it should be "trivially" possible to create a temperature reached signal, output that onto an I/O pin and feed back that I/O into an input pin for which to wait for with M66 and an proportionately long timeout. Or maybe even without using actual pins by just connecting the right signals?
Thanks for pointing me towards this.
That link says:
and
20 Mar 2018 17:43 #107631
You can do something like this in G-code
linuxcnc.org/docs/2.7/html/gcode/o-code.html#ocode:looping
#1 = 220
O100 DO
M66 E0
G4 P1
O100 WHILE [ #5399 LT #1]
20 Mar 2018 22:14 #107643
Replied by rodw on topic Temperature Control
Just a thought.
Nothing moves in LinuxCNC until the spindle is at speed.
Consider using the motion.spindle-at-speed pin to tell the system when the print head is at temperature
It might be easier to use spindle S commands to set the temperature which you could read on motion.spindle-speed-out
21 Mar 2018 12:21 #107654
by B9T
Both of those options look interesting, I'll have to experiment with them. Thank you
22 Jul 2019 12:38 #140169
by superman
Replied by superman on topic Temperature Control
Hi all,
maybe is a late reply to this topic but I havea similar problem. I am trying to adjust the temperature of my 3d printer extruder. For this I have LinuxCNC and the Mesa 7i76.
I have set the first 4 pins of the GPIO to analog inputs and I have plugged in my 100k thermocouple in one of them. Besides I have one digital output connected to a controller like this
In other thread I was recommended to use the lincurve command to convert the voltage to °C, so I did and it works great.
The problem comes now with the PID and PWM parameters. I know that setting up a PID takes time but I think there are some other parameters that must be first set like maxerror, maxoutput, pwm.freq, pwm.scale, etc.
I have set the PID output to PWM value and I know depending on "value" the duty cycle is calculated. One example problem that I have is I set pwm.scale and pid.maxoutput to 255 and this occurs:
- When warming up there is a moment when feedback is bigger than command (Overshoot) –> negative error!
Negative error leads to negative output –> pwm.value = 0 –> dc = 0 –> pin is closed
This is acceptable I guess, but:
- Although pin is closed, feedback from sensor is rising for a while until reached a certain value, so that the error reach negative maxoutput in the end (-255)
- The temperature starts decreasing and output value is bigger but still negative, so when the extruder should be warmed up it is not, and temperature continues decreasing until reaching a difference around 20°C
- By this time pid output is positive and extruder starts to warm up again
My .hal file looks like this:
loadrt lincurve count=1 personality=16
loadrt pwmgen output_type=0,0
addf lincurve.0 servo-thread
addf extruder-pid.do-pid-calcs servo-thread
addf pwmgen.make-pulses servo-thread
# Link analog inputs from 7i76 card to lincurve.0 input
net extruder-sensor-raw lincurve.0.in <= hm2_5i25.0.7i76.0.0.analogin0
# EXTRUDER SETTINGS
setp lincurve.0.x-val-00 0.65
setp lincurve.0.y-val-00 0
setp lincurve.0.x-val-01 1.54
setp lincurve.0.y-val-01 20
setp lincurve.0.x-val-02 1.83
setp lincurve.0.y-val-02 25
setp lincurve.0.x-val-03 3.06
setp lincurve.0.y-val-03 40
setp lincurve.0.x-val-04 5.11
setp lincurve.0.y-val-04 60
setp lincurve.0.x-val-05 7.17
setp lincurve.0.y-val-05 80
setp lincurve.0.x-val-06 8.84
setp lincurve.0.y-val-06 100
setp lincurve.0.x-val-07 9.99
setp lincurve.0.y-val-07 120
setp lincurve.0.x-val-08 10.73
setp lincurve.0.y-val-08 140
setp lincurve.0.x-val-09 11.18
setp lincurve.0.y-val-09 160
setp lincurve.0.x-val-10 11.46
setp lincurve.0.y-val-10 180
setp lincurve.0.x-val-11 11.64
setp lincurve.0.y-val-11 200
setp lincurve.0.x-val-12 11.75
setp lincurve.0.y-val-12 220
setp lincurve.0.x-val-13 11.82
setp lincurve.0.y-val-13 240
setp lincurve.0.x-val-14 11.87
setp lincurve.0.y-val-14 260
setp lincurve.0.x-val-15 11.9
setp lincurve.0.y-val-15 280
setp extruder-pid.enable 1
setp extruder-pid.Pgain 1
setp extruder-pid.Igain 0
setp extruder-pid.Dgain 0
setp extruder-pid.maxoutput 255
setp extruder-pid.maxerror 255
setp extruder-pid.command 180
setp extruder-pid.FF0 0
setp extruder-pid.FF1 0
setp extruder-pid.FF2 0
setp pwmgen.0.enable 1
setp pwmgen.0.scale 255
setp pwmgen.0.pwm-freq 8
net extruder-sensor-interp lincurve.0.out => extruder-pid.feedback pyvcp.extruder-sensor
# EXTRUDER VALUES PYVCP
net extruder-sensor-raw => pyvcp.extruder-voltage
net extruder-pwm extruder-pid.output => pwmgen.0.value pyvcp.extruder-output
net extruder-error extruder-pid.error => pyvcp.extruder-error
net extruder-heater pwmgen.0.pwm => hm2_5i25.0.7i76.0.0.output-05
23 Jul 2019 11:51 #140284
You have a system where a negative PWM has no meaning (you don't have active cooling)
I am slightly surprised to find that there is no way to force the PID to be single-sided built in to the component.
So, the answer is probably to add a limit HAL component between the PID output and the PID input..
You might need to limit the I error in the PID to prevent wind-up in the I term when over setpoint.
02 Apr 2024 20:23 #297461
by lkavan
Replied by lkavan on topic Temperature Control
Hallo,
I have similar problem with temperature control and I would like to ask if you have found a solution. I need to control selective soldering wave. I have used 7I96S to control machine and 7I87 to measure temperature with thermocouple to voltage amplifier. I have used hal components pid and pwmgen to control the heater. Well, it works somehow. But I have the same problem with negative output from pid. I think, limit between pid out and pwm in will not solve it. Have anybody found better solution? It seems there is still not pid component with positive output only. And the second problem - I would like to have a signal, that temperature is OK, to block the tin pump (connected as a spindle) when tin temperature is too low and it is not liquid.
Thanx a lot.
Thanx a lot.
02 Apr 2024 21:13 #297469
Replied by PCW on topic Temperature Control
Yes, it would be nice to have a single ended PID comp or PID mode.
Maybe better would be a more temperature control friendly comp
that implements MPC or similar.
You could use the "near" or "comp" components to enable your pump.
The following user(s) said Thank You: lkavan
02 Apr 2024 21:53 #297472
You could also use wcomp or comp to disable the PID when the temperature was above setpoint. I am not sure how elegantly that would work, though.
If the problem is integral wind-up when over-temperataure then one solution might be to set up a second lincurve component that sets the I-gain to zero when the error is negative.
I used to tune vehicle idle speed controllers, and those used this idea, except that P, I and D gains were all 8x8 maps agains error and coolant temperature.
Time to create page: 0.153 seconds
