Closed loop with steppers
16 Feb 2018 18:23 #106033
by Pasteur
Closed loop with steppers was created by Pasteur
Hello everybody.
I'm a little new in LinuxCNC , and I wanna make a simple question.
How could I implement a closed loop for a stepper motor in LinuxCNC?
I'm gonna to do the most clear that I can to explain my problem.
I have a machine that have different backlash in different points. I have a very precise rulers that can measure the position of the tool and I want to connect this rulers to LinuxCNC (I guess that is possible with HAL) and correct the trajectory in real time creating the closed loop.The trajectory correction , I guess in this case, is only add more pulses to the motor if the tool not reach the indicated position by G-Code. I understand that in theory is simple and I read that is possible but I don't know how that is possible.
I read, also , that is possible using a PID but I don't know if it is real or no.
Beyond my previous question , I want to know if this is implemented in LinuxCNC or I must design a HAL component to do it possible.
Thanks!
Thanks!
- Thank you received: 1370
16 Feb 2018 18:53 #106037
Replied by Todd Zuercher on topic Closed loop with steppers
You would do it using a PID loop, but be careful step motors do not always respond well to this. (it can lead to stalling)
The problem being if the pid is detecting a stall, it will command the stepper to move faster to catch up which will insure that it will stall, the opposite of what is needed to prevent a stepper from stalling.
27 Feb 2018 19:35 #106651
by Pasteur
Replied by Pasteur on topic Closed loop with steppers
Ok thanks Todd , but after I researched in many sites I reach at the conclusion that I must write a HAL component because the PID will cause problems, but first I need understand how PID is configured in HAL file I guess. Basically I guess I need a very good example of PID configuration , I write to you because the linuxcnc's forum is large and maybe you know about a very good one configuration example .
My first doubt is how configure the 'feedback' in HAL with PID. If I know that, I guess that I can start with some tests
I will apreciate your answer.
Bye!
Bye!
- raglanlittlejohn
- Thank you received: 9
27 Feb 2018 20:20 #106658
by raglanlittlejohn
Replied by raglanlittlejohn on topic Closed loop with steppers
Heres a schematic I did (one axis shown only), with a couple of other contributers links. I don't think you need a new component. I use 2000 ppr encoders in quadrature with index. It's useful for keeping track of true position, and homing.
The following user(s) said Thank You: tivoi
05 Mar 2018 21:19 #106975
Replied by andypugh on topic Closed loop with steppers
You should be able to do it with PID without too many problems.
The trick is to set the step-generators to velocity mode, and then the PID component requests a speed of movement required to keep the error low.
You shouldn't need a special HAL component.
But you probably will need to tune the PID loop, just as you would with a velocity-mode servo,
Time to create page: 0.189 seconds
