component compile problem
- Skidloaders1
14 Apr 2018 11:13 #108993
by Skidloaders1
component compile problem was created by Skidloaders1
Good day all
trying to write my first component but have failed to compile so far
Reduced file to smallest possible.but no matter what i write ,I keep getting the same error message ( even when using component from others )
see below
FUNCTION _;
If (toolchange == true )
turn-turret = true;
wil@wil:~/Desktop/Weiler-DDR$ sudo halcompile --compile turr.comp
File "/usr/bin/halcompile", line 1353, in <module>
main()
File "/usr/bin/halcompile", line 1322, in main
process(f, mode, outfile)
File "/usr/bin/halcompile", line 1192, in process
a, b = parse(filename)
File "/usr/bin/halcompile", line 417, in parse
a, b = f.split("\n;;\n", 1)
ValueError: need more than 1 value to unpack
Wrote program on linux with gedit ( no Windows any where near it )
Wilfried
see below
FUNCTION _;
turn-turret = true;
main()
Wilfried
14 Apr 2018 15:14 #108999
by gaston48
Replied by gaston48 on topic component compile problem
Hello,
Simple Component Example:
component ddt "Compute the derivative of the input function";
pin in float in;
pin out float out;
variable double old;
function _;
license "GPL"; // indicates GPL v2 or later
float tmp = in;
out = (tmp - old) / fperiod;
old = tmp;
;; is important and justified left
pin in float in;
pin out float out;
function _;
float tmp = in;
old = tmp;
14 Apr 2018 20:43 #109011
by Grotius
Replied by Grotius on topic component compile problem
Maybe you can try : sudo halcompile ....
I have made variant's of thcud component. But next time i will try to make a mini tutorial how to compile a component.
- Skidloaders1
15 Apr 2018 09:47 #109060
by Skidloaders1
Replied by Skidloaders1 on topic component compile problem
Good day linuxcnc
Quote => " But next time i will try to make a mini tutorial how to compile a component."
Grotius I'm sure this will be welcomed by a lot of CNC enthousiast and the like.
I don't understand the programming requirements for a component very well.
I found a very nice online C editor and compiler.
www.onlinegdb.com/online_c_compiler
but when typing in a component program it does not react very well at all
However, I did learn from it that turn-turret does not compile , but turn_turret does.
1)Is it possible to troubleshoot ( debug ) one's program in a non linuxcnc terminal environment?
2)What is the difference between a component for linuxcnc and a C program ?
p.s. my lathe is at work (15 min) from home where I have 380Volt.
Wilfried
Wilfried
15 Apr 2018 12:28 #109064
Replied by rodw on topic component compile problem
You really need to read the docs (master branch shown)
linuxcnc.org/docs/devel/html/hal/comp.html
C is a programming language. Hal components are written C like but there are some rules about the construction as you found out about underscores and hyphens.
components are usually compiled using halcompile which is a program that takes the .comp file as input, converts it to a C module, compiles and installs it so it is seen by Linuxcnc.
Normally you compile and install a component like this.
halcompile --install rtexample.comp
- Skidloaders1
16 Apr 2018 16:14 #109130
by Skidloaders1
Good day All
Have tried any and every program and its variant but keep getting the same error.
nl.
wil@wil:~/Desktop/Weiler-DDR$ sudo halcompile --install constant.comp
main()
I have to conclude that the problem is not with the component.
But what else could it be ?
Had a look at Jeff Eplers Halcompiler program where line 1353 =>
main ()
whitch is the last line of the program.
do i have corrupt or missing file or files ??
It leaves me completely clueless.
any guidance would me most welcome
Wilfried
nl.
main()
main ()
Wilfried
- Skidloaders1
17 Apr 2018 16:21 - 19 Apr 2018 15:42 #109206
by Skidloaders1
Hi all
Have now compiled ddt.comp on other linuxcnc machine and it worked just fine.
Also reinstalled linuxcnc-dev , but with no change to the result.
Is it possible to compile on other unit and transfer the files to the machine I need them in ??
reinstall linuxcnc ?????
currently running linuxcnc 2.7.12 .
Wilfried
Wilfried
Last edit: 19 Apr 2018 15:42 by Skidloaders1.
19 Apr 2018 20:15 - 20 Apr 2018 01:17 #109307
by JR1050
Replied by JR1050 on topic component compile problem
i think you have several syntax errors
FUNCTION _;
turn-turret = true;
C is case sensitive " If" is not the same as" if"
you will need to declare what your variables/ hal pins are
names should be in sequential parenthesis
you have to name the component
Spend some time in the hal manual and look up the toolchange comp for the first guy that retrofitted an HNC, it is very simple and makes sense. His first name was Kurt.
Most important, you have to know what you really want your component to do, you might try "hello world" with the gcc. Halcompile is for hal components.
so , more like this
component tool change;
pin in bit tool_change;
pin out bit turn_turret ;
function( _);
if((tool_change)==1){
turn_turret =1;
Im a big fan of components for plc functions, but it is a large learning curve.Ladder might be easier.
FUNCTION _;
turn-turret = true;
so , more like this
function( _);
turn_turret =1;
Last edit: 20 Apr 2018 01:17 by JR1050.
- Skidloaders1
20 Apr 2018 15:22 #109338
by Skidloaders1
Thank you JR1050 for your kind help.
I realise that learning to write components is not going to be a overnight success.
I tried your code , once again with no different result.
Not looking forward to reinstall linuxcnc - ( or the full Debian .)
But looks like I have no choice.
best Wilfried
best Wilfried
- Skidloaders1
20 Apr 2018 15:26 #109339
by Skidloaders1
hope to write component for my Weiler lathe
see
see
Time to create page: 0.207 seconds
