Unexpected realtime delay and genserkins
- Thank you received: 5979
18 Apr 2018 22:08 #109274
Replied by tommylight on topic Unexpected realtime delay and genserkins
Is that a laptop you are using?
- Cornflakes
19 Apr 2018 05:12 #109281
by Cornflakes
Replied by Cornflakes on topic Unexpected realtime delay and genserkins
I changed the order, but no effect
After homing:
motion.servo.last-period = 3500000
servo-thread.tmax = 1120000
When error appears:
servo-thread.tmax = 14000000
My PC is desktop: Pentium Core Duo, chipset H110
After homing:
When error appears:
19 Apr 2018 10:27 - 19 Apr 2018 10:33 #109287
Replied by PCW on topic Unexpected realtime delay and genserkins
Are you sure you have a H110? That's a relatively current chipset for LGA 1151 CPUs
I would expect something like a P35 G41 or 9X5 series on a Core Duo (a 10 year old chipset)
Your worst case latency is 4X you servo period so its not surprising you are getting real time errors
are these numbers with your 3.5 ms (3500000 ns )servo thread?
If so that's even more mysterious, since that means your CPU clock is about 1 GHz (and there are no desktop Core Duo CPUs
that run at 1 GHz AFAIK)
Do you have the Motherboard and CPU part numbers?
Last edit: 19 Apr 2018 10:33 by PCW.
- Cornflakes
19 Apr 2018 10:42 #109289
by Cornflakes
INTEL Pentium Dual-Core G4560
MSI H110M PRO-VD PLUS
19 Apr 2018 11:06 - 19 Apr 2018 11:17 #109291
OK that makes more sense (that's not a Core Duo that's a current Pentium dual core CPU)
What was the servo thread setting that generated your timing numbers?
Also what does
uname -a
print?
Also what does
uname -a
print?
Last edit: 19 Apr 2018 11:17 by PCW.
- Cornflakes
19 Apr 2018 11:28 #109292
by Cornflakes
"uname -a" does:
Linux debian22 3.2.0-5-rt-686-pae #1 SMP PREEMPT RT Debian 3.2.96-3 i686 GNU/Linux
ini:
SERVO PERIOD 1000000
ini:
19 Apr 2018 14:12 #109294
OK so that means something is causing ~ 4 milliseconds latency on your system
Do you have all speed-step / turbo modes / power saving options disabled in your BIOS?
- Cornflakes
19 Apr 2018 14:20 #109295
by Cornflakes
Yes! These options are disabled
19 Apr 2018 15:15 #109297
Hmm, maybe I didn't read as carefully as I should have, wouldn't be the first time...
Is this possibly only a problem with genserkins?
That is, if you make a dummy config with loadrt genserkins and all references to its pins commented out,
do you still have the same real time issues?
19 Apr 2018 15:37 #109299
Another thing that might help isolate the issue is looking at these times
hm2_7i92.0.read.tmax
hm2_7i92.0.write.tmax
motion-command-handler.tmax
motion-controller.tmax
