Lead-screw Compensation
25 May 2018 00:59 #111099
by silden
Lead-screw Compensation was created by silden
Hi Guys,
I read the Wiki and several post how to implement/activate the lead-screw compensation, but I cloud not get it to work.
I generated the compensation file for my Z axis with the name Z.comp.
This file is in the same location as the .ini and .hal.
I added the following lines to the AXIS 2 portion of the INI.
COMP_FILE = Z.comp
COMP_FILE_TYPE = 0
I started LinuxCNC and tested the compensation with my dial gauge.
This revealed that the compensation is not active.
I believe that I am missing something in my config and unable to locate it.
Thank you in advance
COMP_FILE = Z.comp
COMP_FILE_TYPE = 0
29 May 2018 13:29 #111258
Replied by andypugh on topic Lead-screw Compensation
You should be able to see the correction value with Halmeter (Machine -> Halmeter in the Axis GUI )
axis.N.backlash−corr
Is the pin to look at
If you are not using Axis then feel free to enquire where to find halmeter.
07 Jun 2018 13:05 #111869
by silden
Replied by silden on topic Lead-screw Compensation
Thank you for your reply.
I have checked with the HAL Meter and the axis.2.backlash-corr is 0.
I changed the file name and reference in the INI, but it seems not to do anything.
Should I somehow activate backlash compensation in the HAL?
Thank you
Thank you
07 Jun 2018 13:15 #111872
Is the INI entry definitely in the right section of the INI?
(which version of LinuxCNC are you using?)
The file path needs to be relative to the INI file, or an absolute path.
07 Jun 2018 13:21 #111874
by silden
I tried absolute path and relative to the INI.
The compensation file is in the same folder as the INI.
I attached my INI and compensation file for reference.
07 Jun 2018 16:06 #111892
I don't see anything obviously wrong.
Two things worth trying:
COMP_FILE=./Z.comp
(ie, explicitly state "current folder"
Add an extra LF at the end of the last line of the file.
Is there any chance that your computer is set to a locale that uses , rather than . for the decimal separator?
COMP_FILE=./Z.comp
The following user(s) said Thank You: silden
23 Aug 2018 10:57 #116480
by Python
Replied by Python on topic Lead-screw Compensation
Hello, I've been adding this feature to my machine because of inaccuracies in both x and y axis. And with the x axis everything works fine, but with y I have some issues. My machine setup is that x axis are traveling in positive coordinates direction, but y axis is traveling to the negative coordinates (work table). And then I write COMP_File with the negative coordinates, Linux CNC gives me an error "joint1: compensation values must increase". so The question is there a way to work around that error without changing Y axis travel to the positive side?
23 Aug 2018 11:54 #116482
Just re-sort the comp file into an increasing sequence.
The system reads the current position then interpolates from the comp file values.
The interpolation algorithm needs the values to increase. But that has no relationship to the direction of movement of your physical axis.
13 Mar 2019 12:32 #128510
by Python
Thank you very much, this information that you shared helped a lot at a time. Thank you very much.
14 Mar 2019 16:25 #128594
by pl7i92
Replied by pl7i92 on topic Lead-screw Compensation
lead screws are at this time very cheep and mutch more precise as in the early mashine building years
even Trapezional are on less then 0,05 Backlash at 1meter
and a Balscrew C7 is for so cheep Money avalable to be changed if there is a leak
considder to replace the system
Time to create page: 0.308 seconds
