Serial absolute encoders
11 Jun 2018 17:38 #112206
by Deckerjwd
Serial absolute encoders was created by Deckerjwd
have a motoman sk150 the encoders can send out there position from home as a rs-232, they also give a standard incremental output. is there a way to on power on read 6 serial ports and feed the position in to the current position? the best thing would to be reading the com ports real time but there seem to be problems with this
11 Jun 2018 17:44 #112208
Replied by PCW on topic Serial absolute encoders
Do these use the Yaskawa protocol? (quadrature A pin is serial ASCII at 9600 baud at startup)
I have been considering supporting this
11 Jun 2018 17:47 #112209
by Deckerjwd
Replied by Deckerjwd on topic Serial absolute encoders
yes but they have what they call Phase S also and it is a 1 way rs422 that you can read with pin 2 and 5 on a standard serial port
12 Jun 2018 15:14 #112242
by Deckerjwd
looks like i need to rebuild a motor on this arm, but what would you need to support this? i have a spec sheet and a few working encoders(5 so far)
13 Jun 2018 12:23 #112283
Do you know what the encoders are? I have a feeling that the STMBL servo drive can read this type of encoder.
Are you looking to run the original drives with the arm?
Replied by andypugh on topic Serial absolute encoders
13 Jun 2018 17:18 #112296
by Deckerjwd
the encoders are labled utmae-b12be5w from Yaskawa. the original drives are CACR-IR44sfb. i don't plan on running them of the original drives as the com info is in Japaneses only.
here is the PDF on the encoders they seem to be type 2. i have connected them to a com ports as shown on
page 10 and used a putty to view the position info and error data. all 6 of the encoders work and 5 out of the 6 motors have been tested and 4 of 6 work with abb microflex drives, but for 3 of the motors this will be to small and no absolute data is read by the drives.
13 Jun 2018 17:29 #112298
github.com/rene-dev/stmbl/blob/master/do...tting%20Started.adoc
Suggests there is an interface for Yaskawa for STMBL.
Source-code here:
github.com/rene-dev/stmbl/blob/master/src/comps/yaskawa.c
The big problem with the STMBL is getting one.
Source-code here:
13 Jun 2018 20:31 #112321
by Deckerjwd
cool i will dig in to this, i see a prolbem though there to small even if i can get one. the 3 big motors are 4.4kW and looks like 2.2kW is as big as it will go.
Time to create page: 0.230 seconds
