Automatic touchoff of face mill
28 Jun 2018 14:51 #112988
by cahlfors
Automatic touchoff of face mill was created by cahlfors
Dear forum,
I am not an expert user, but with the help of the wiki and forum, I have been able to remap M6 to do automatic touchoff quite nicely. Recently, I got a large face mill and this introduces a problem. The touchoff coordinates are fixed and centers the tool over the touchoff button (which is screwed to the table). However, the face mill is hollow in the center. It would need to be positioned a tool radius to the side, in order to measure at the cutting points . How can this be accomplished?
Thanks for any pointers,
/Chrishttps://forum.linuxcnc.org/10-advanced-configuration/topic/create#write
28 Jun 2018 16:57 #112999
by Sparky961
Replied by Sparky961 on topic Automatic touchoff of face mill
Why M6? When I see an M6 in a program, the only thing I expect it to do is change the tool. On a mill that usually includes raising the spindle and whatever automatic mechanisms exist to physically swap out the tool. If you're the only one using the machine then it's not so horrible, but what you're doing certainly strikes me as non-standard and could cause a safety issue if someone isn't expecting it to come down on the touch plate. I'd suggest using a different M-code for your custom functionality.
The following user(s) said Thank You: cahlfors
28 Jun 2018 19:43 #113014
Replied by andypugh on topic Automatic touchoff of face mill
If you program in the tool diameter in the tool table then you can make your probe routine offset by one tool radius. This is probably also appropriate for smaller cutters, so doesn't need special handling.
G53 G0 X[100 - #5410] Y100
You could, alternatively, turn on cutter diameter compensation before the move to the probing station.
linuxcnc.org/docs/2.7/html/gcode/overview.html#gcode:parameters
29 Jun 2018 08:59 #113068
by cahlfors
Replied by cahlfors on topic Automatic touchoff of face mill
Thank you both for valuable input!
Andy's suggestions are exactly what I was looking for and I will go for that for now, but perhaps remapping to accomplish automatic tool length measuring is a bad idea? I am the only one using this machine but, since remapping, the "program pointer" no longer points to the correct location in the g-code, which is awkward.
Also, the place where I found the code is gone:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...ch;hb=refs/heads/2.6
Maintaining will be difficult and I am still on 2.6...
@Sparky, do you have a better suggestion using other M or G codes?
Thanks,
/Chris
Thanks,
/Chris
29 Jun 2018 09:33 #113070
If your tool-holding arrangement can not load to a consistent tool length then I think that automatic tool length measurement is a good solution. Doing it as a remap is more convenient than doing it by adding a subroutine to the G-code and is more compatible with CAM systems, so I think it is the correct way to go.
The entire LinuxCNC git archive moved, the sample config you used still exists, but has moved to here:
github.com/LinuxCNC/linuxcnc/tree/master...h-tool-length-switch
29 Jun 2018 16:09 #113100
by cahlfors
Thanks Andy,
I really appreciate this!
/Chris
/Chris
18 Feb 2019 18:50 #126721
by cahlfors
I am having another go with this:
Ideas?
/Chris
It turns out that #5410 is always zero for me. I have added a non-zero diameter in the tool table for a specific tool, reload the tool table and change to that tool. Still zero.G53 G0 X[100 - #5410] Y100
Ideas?
/Chris
26 Feb 2019 20:55 #127187
12 May 2019 14:25 #133557
by cahlfors
Had some more time to tinker with this. It turns out that #5410 et al contain information about the *current* tool, not the one we are changing *to* and so cannot be used in the remap code. I suppose that enabling cutter compensation would suffer from the same problem. Is there a way to find out the tool diameter in the remap code?
18 May 2019 11:45 #134174
G43 takes an optional H parameter, so you can issue a G43 to load the offsets for the next tool and read out the diameter from #5410 without physically changing tool.
You probably then want to zero-out the offsets (G49) before probing and finally load the new offsets at the same time as issuing the M6.
Time to create page: 0.235 seconds
