A little help to finish my hexapod
28 Jul 2018 11:53 #115007
by topone
Replied by topone on topic A little help to finish my hexapod
Hi andypugh
As you have suggested I have looked the source code
github.com/LinuxCNC/linuxcnc/blob/master...ematics/genhexkins.c
and i think a little change of the code can resolve my problem.
So I have installed linuxcnc following this guide: linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html -->7.2. Installing on Ubuntu Precise.
If I compile with
halcompile --install genhexkins.c
I have this error:
/tmp/tmpOdWCxO/genhexkins.c: In function kinematicsForward
/tmp/tmpOdWCxO/genhexkins.c:468:7: error: implicit declaration of function rtapi_fabs [-Werror=implicit-function-declaration]
-- followed by other similar errors --
I think some libraries are not linked correctly. Why?
something else
I also noticed that in the installation procedure it refers to the link
releases.ubuntu.com/precise/
leading to
Ubuntu 12.04.5 LTS (Precise Pangolin)
This installation does not work (i think for a wrong kernel version), it is necessary to use the Ubuntu 12.04 LTS (Precise Pangolin) (version hard to find)
Thanks.
If I compile with
I have this error:
something else
leading to
Thanks.
28 Jul 2018 15:07 #115012
by topone
I have reinstalled ubuntu (great fsarchiver), reinstalled LinuxCNC and then copied this 2 files
github.com/LinuxCNC/linuxcnc/blob/master...ematics/genhexkins.h
i have copied genhexkins.h on the /usr/include/linuxcnc/ folder, and now i can compile.
make KBUILD_EXTRA_SYMBOLS=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-3.4-9-rtai-686-pae SUBDIRS=`pwd` CC=gcc V=0 modules
make[1]: ingresso nella directory "/usr/src/linux-headers-3.4-9-rtai-686-pae"
CC [M] /tmp/tmpW0KzgX/genhexkins.o
Building modules, stage 2.
MODPOST 1 modules
WARNING: "pmRpyMatConvert" [/tmp/tmpW0KzgX/genhexkins.ko] undefined!
WARNING: "pmCartCartCross" [/tmp/tmpW0KzgX/genhexkins.ko] undefined!
WARNING: "pmCartUnit" [/tmp/tmpW0KzgX/genhexkins.ko] undefined!
WARNING: "pmMatCartMult" [/tmp/tmpW0KzgX/genhexkins.ko] undefined!
WARNING: "pmCartCartAdd" [/tmp/tmpW0KzgX/genhexkins.ko] undefined!
WARNING: "pmCartUnitEq" [/tmp/tmpW0KzgX/genhexkins.ko] undefined!
WARNING: "pmCartCartDot" [/tmp/tmpW0KzgX/genhexkins.ko] undefined!
WARNING: "pmCartMag" [/tmp/tmpW0KzgX/genhexkins.ko] undefined!
WARNING: "pmCartCartSub" [/tmp/tmpW0KzgX/genhexkins.ko] undefined!
CC /tmp/tmpW0KzgX/genhexkins.mod.o
LD [M] /tmp/tmpW0KzgX/genhexkins.ko
make[1]: uscita dalla directory "/usr/src/linux-headers-3.4-9-rtai-686-pae"
cp genhexkins.ko /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/
Now, if i run linuxcnc and select Hexapod this happen
LINUXCNC - 2.7.14
Machine configuration directory is '/usr/share/doc/linuxcnc/examples/sample-configs/sim/axis/vismach/hexapod-sim'
Machine configuration file is 'hexapod.ini'
Starting LinuxCNC...
Found file(REL): ./core_sim_6.hal
insmod: error inserting '/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/genhexkins.ko': -1 Unknown symbol in module
./core_sim_6.hal:4: exit value: 1
./core_sim_6.hal:4: insmod for genhexkins failed, returned -1
See the output of 'dmesg' for more information.
LinuxCNC terminated with an error. You can find more information in the log: /home/cnc/linuxcnc_debug.txt
and /home/cnc/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal
this the dmesg report
[ 6503.438802] RTAI[math]: loaded.
[ 6503.471489] genhexkins: Unknown symbol pmCartCartSub (err 0)
[ 6503.471509] genhexkins: Unknown symbol pmCartMag (err 0)
[ 6503.471523] genhexkins: Unknown symbol pmCartCartDot (err 0)
[ 6503.471534] genhexkins: Unknown symbol pmCartUnitEq (err 0)
[ 6503.471545] genhexkins: Unknown symbol pmCartCartAdd (err 0)
[ 6503.471556] genhexkins: Unknown symbol pmMatCartMult (err 0)
[ 6503.471566] genhexkins: Unknown symbol pmCartUnit (err 0)
[ 6503.471577] genhexkins: Unknown symbol pmCartCartCross (err 0)
[ 6503.471586] genhexkins: Unknown symbol pmRpyMatConvert (err 0)
[ 6503.634707] RTAI[math]: unloaded.
I suppose halcompile don't work, WARNING: "pmRpyMatConvert" [/tmp/tmpW0KzgX/genhexkins.ko] undefined! is an error. Is this correct?
MODPOST 1 modules
LINUXCNC - 2.7.14
28 Jul 2018 15:24 #115014
Replied by andypugh on topic A little help to finish my hexapod
It may be that you can't compile genhexkins with halcompile.
halcompile works with _some_ kinematics files, I think, but not those with certain #includes.
It looks like you don't have posemath.h (at a guess)
28 Jul 2018 21:02 #115027
by topone
posemath.h is present and it is on the same folder of genhexkins.h.
I think it is possible to compile genhexkins with halcompile. I have found this post:
forum.linuxcnc.org/forum/10-advanced-con...g-genhexkins?limit=6
I have open posemath.h with gedit and saved it using Unix/Linux line endings, as suggest on the post but I have the same problem.
It seems it is necessary install some packages, but I don't understand which.
28 Jul 2018 22:47 #115032
You could try apt-get install linuxcnc-dev
(I don't know for sure that that package still exists as a separate thing)
29 Jul 2018 07:07 #115043
by topone
linuxcnc-dev is already installed.
sudo apt-get install linuxcnc-dev
[sudo] password for cnc:
Lettura elenco dei pacchetti... Fatto (Read list of packages... Done)
Generazione albero delle dipendenze (Dependency tree generation)
Lettura informazioni sullo stato... Fatto (Reading status information... Done)
linuxcnc-dev è già alla versione più recente (linuxcnc-dev is already at the latest version).
I can't understand...
29 Jul 2018 13:59 #115060
I am not very familiar with compiling code (I just tend to type "make" and trust someone else to have written a good makefile)
This is where halcompile does the actual compiling.
github.com/LinuxCNC/linuxcnc/blob/master...ls/halcompile.g#L708
You can see that the build_usr and build_rt files both create a makefile then run 'make" on it.
the makefile is probably deleted, but there might be a way to prevent that.
Then you might be able to add the extra makefile entries to find the posemath libraries.
It might just be easier to download all the LinuxCNC source and compile everything, including your new genserkins.
Time to create page: 0.143 seconds
