Compile problems
26 Jul 2018 11:26 #114869 by SINGH
Open NC files in AXIS was created by SINGH
please tell me how to fix this problem....?
checking whether readline license is compatible with GPL-2... no
configure: WARNING: The LinuxCNC binary you are building may not be
distributable due to a license incompatibility with LinuxCNC (some portions
GPL-2 only) and Readline version 6 and greater (GPL-3 or later).
configure: error: To configure LinuxCNC in this way, you must
invoke configure with "--enable-non-distributable=yes". Note that on
Debian-based systems, you may be able to use libreadline-gplv2-dev instead.
26 Jul 2018 14:58 #114889 by andypugh
Replied by andypugh on topic Open NC files in AXIS
Query moved here and renamed. Was originally in the Axis section.
26 Jul 2018 15:43 #114897 by PCW
Replied by PCW on topic Open NC files in AXIS
Note that on Debian-based systems, you may be able to use libreadline-gplv2-dev instead.
did you try:
sudo apt-get install libreadline-gplv2-dev
26 Jul 2018 16:57 - 26 Jul 2018 17:03 #114901 by Grotius
Replied by Grotius on topic Open NC files in AXIS
If i read this :
Can the solution be in terminal at the point of mr.singh installation :
cd src
./autogen.sh
./configure --enable-non-distributable=yes
document : github.com/KurtJacobson/RF45-CNC/wiki/Bu...LinuxCNC-From-Source
It's a very strange message. It looks like someone has made a macintosch or apple application inside linuxcnc. :laugh: :woohoo:
@Andy,
It's nice to see a admin doing his job !
Last edit: 26 Jul 2018 17:03 by Grotius.
26 Jul 2018 23:16 #114918 by InMyDarkestHour
Not a strange message just a "debian thing" lol
29 Mar 2023 11:19 #267788 by jalajc
Replied by jalajc on topic Open NC files in AXIS
Solution: on recent version of Debian and Ubuntu, please install libeditreadline-dev which is still GPL2 for dependency fullfillment.
  1. if you have installed libreadline-dev remove by
    sudo apt remove libreadline-dev
  2. and install still GPL2 compatible libreadline via
    sudo apt install libeditreadline-dev
  3. Build the package again by
    dpkg-buildpackage -b -uc
You should not encounter the error now.
Background: I faced the same problem, and I was compiling on RPi 400 (4GB) with Ubuntu 22.04 LTS (jammy). Reason was readline versions are GPL3 (libreadline-dev) but Latest repo of Debian and Ubuntu don't have GPL2 compatible versions on standalone. Some other product was facing this issue (matter of fact MariaDB) so they used libeditreadline-dev as GPL2 compliant requirement is fullfilled by this flavor of readline. worked for me too.
____
if you think my solution helped, please appreciate so that I know, other people are also trying similar stuffs
Time to create page: 0.181 seconds
