Logarithm
08 Nov 2018 19:23 #120284
by yeepah
Hy
I feel dumb
I try to install this code as compoment file .comp:
float thermistor2temperature(float R) {
float T;
if (R<=0)
R=0.001; // avoid log(0)
T = 1.0/ ( 1.0/T0 + (1.0/ * log(R/R0) );
return T;
I do include #include <rtapi_math.h>
During compilation i get error : implicit declaration of function 'log'
What am I doing wrong???
thanks
I feel dumb
float T;
if (R<=0)
return T;
thanks
09 Nov 2018 12:07 #120325
by yeepah
I thought that also. And I try it again.
I even try with with a log alone like
double R = log(133)
but it return alway the same error
I'm a bit lost
Do you have an idea were can i find a log code function. I could write it but my mathematique skill are a bit poor.
double R = log(133)
I'm a bit lost
09 Nov 2018 13:17 #120328
Hmm, log() is not included in rtapi_math.h github.com/LinuxCNC/linuxcnc/blob/master/src/rtapi/rtapi_math.h
I would search for the C code in the GCC compiler for the log function and add it to my component.
Or try and add it to the header file....
09 Nov 2018 13:22 #120329
I don't see a log function in rtapi_math.
There is a simple (recursive) log2() function here:
www.geeksforgeeks.org/program-to-compute-log-n/
And log10(N) = log2(N)/log2(10)
I just noticed that the log2 above is calculated as an integer, so might not give the accuracy you need.
Why do you need a logarithm in HAL? Maybe there is another way?
09 Nov 2018 14:00 #120330
by yeepah
thanks for your answers
I will work on that
I using linuxcnc to drive a reprap. I'm following and adapting the work of this guy.
www.anderswallin.net/2012/12/temperature-pid-control-part-deux/
Using hal encoder with NTC resistor and ne555 chip to control PID and pwmgen.
Thermistor change a frequency read by linuxcnc.....regulate extruder and hotbed temperature
To calcul the temperature with the frequency I need a log
I will work on the direction you give. And come back with the result
thanks
I will work on that
thanks
09 Nov 2018 14:09 #120331
LinuxCNC 2.8 (development version) includes this:
linuxcnc.org/docs/devel/html/man/man1/thermistor.1.html
And also this:
linuxcnc.org/docs/devel/html/man/man9/max31855.9.html
But for 2.7 it might be simplest to use this:
linuxcnc.org/docs/devel/html/man/man9/lincurve.9.html
And also this:
Time to create page: 0.220 seconds
