problem figuring out which pins are which on 7i52s
16 Nov 2018 19:46 #120861
by 3D-Master
Replied by 3D-Master on topic problem figuring out which pins are which on 7i52s
can someone explain why /TX0B and /TX3B are good (0v when linuxcnc is closed) but 1,2,4 and 5 have 4.6v when linuxcnc is closed? this doesnt make sense to me
16 Nov 2018 20:16 #120862
Replied by PCW on topic problem figuring out which pins are which on 7i52s
Because TXB0 and TXB3 have enable pins and are disabled when LinuxCNC
is not running.
I would suggest using the TX pins that are in the desired state when LinuxCNC is not running and fixing the running output polarity in the hal file
(or using a output pin for a common drive enable if your drives have a enable input as most PWM drives have)
is not running.
16 Nov 2018 20:39 #120863
by 3D-Master
so in case of TX1B, i would have to write setp hm2_7i80.0.gpio.039.invert_output true ?
16 Nov 2018 21:06 - 16 Nov 2018 21:07 #120864
If the 7i52s is on the first connector, it would be on GPIO19
You should run mesaflash with the --readhmid option to get a pinout file for your
configuration if there is a question about GPIO pin mapping:
mesaflash --device 7i80hd --addr 10.10.10.10 --readhmid > mypins.txt
If you are using LinuxCNC 2.8 you can do this more cleanly
by inverting the PWM pin:
setp hm2_7i80.0.pwmgen.NN.out0.invert_output true
Last edit: 16 Nov 2018 21:07 by PCW.
16 Nov 2018 22:43 #120870
by 3D-Master
okay thank you
17 Nov 2018 16:04 #120902
by 3D-Master
that kinda works but everytime i start up Linuxcnc the motor spools up for a split second, maybe i have to put a relay between the 7i52s pwm and the motor driver or probably use the sleep input but i dont know if it is the enable input. This is what the manual says:
SLP HIGH Inverted sleep input: This pin is pulled high by the driver board, enabling the driver by default; drive SLP low to put the motor driver into a low-power sleep mode.
Does low-power sleep mode mean disabled?
BTW its the Pololu G2 pwm Driver board
17 Nov 2018 18:06 #120913
I would guess that sleep mode means disabled
Another option is disabling the primary servo power on the AC side
with a relay until linuxcnc is running
20 Nov 2018 13:50 #121047
I always do this anyway. The main power relay is controlled by the LinuxCNC "machine on" output.
Replied by andypugh on topic problem figuring out which pins are which on 7i52s
Time to create page: 0.245 seconds
