- Configuring LinuxCNC
- Advanced Configuration
- What is benefit of running the Servo Thread at 4kHz instead of the standard 1kHz
27 Nov 2018 02:14 #121421
by silden
What is benefit of running the Servo Thread at 4kHz instead of the standard 1kHz was created by silden
Hi Guys,
I'm reading bit through the forum and realized that quite a few people run the Servo Thread at 4kHz with the 7i76e.
I started to wonder what the benefit of the speed increase is.
Will this decreased cycle time improve surface finish?
I'm using a 6i25 with 7i76 and 7i85s and the strech rt preempt iso 64bit. The PC is a I5-4670K. Probably overkill, but that is what I had available at the time.
Thanks,
Denis
Thanks,
Denis
- Thank you received: 1370
27 Nov 2018 03:01 - 27 Nov 2018 03:02 #121423
Replied by Todd Zuercher on topic What is benefit of running the Servo Thread at 4kHz instead of the standard 1kHz
Unless you are dealing with extremely high acceleration and velocity with ultra precision it likely won't make much difference on a position commanded servo system.
That said I am running a 4khz servo thread on a machine with torque command input to close the velocity loop.
Last edit: 27 Nov 2018 03:02 by Todd Zuercher.
27 Nov 2018 03:50 - 27 Nov 2018 03:51 #121445
by silden
Replied by silden on topic What is benefit of running the Servo Thread at 4kHz instead of the standard 1kHz
I use Linear Encoder for positioning and like to up the acceleration and velocity for HSM tool paths.
I only have to change the servo thread in the IN/HAL correct?
I'll give it a try and see how it will work.
Last edit: 27 Nov 2018 03:51 by silden.
Time to create page: 0.116 seconds
