How to map a ball screw?
12 Dec 2018 23:40 #122332
by Ross77
How to map a ball screw? was created by Ross77
I'm looking fro help as to the best way to map a ball screw? I understand the comp file structure of commanded vs actual and backlash but want to check what the best way to do the whole process of checking was?
I have some varying errors in my mill, which may be binding in the jibs etc so I need to test the whole system and start by setting the scaling. My suspicion is that it is just the center part that has worn as the ends seem to ok when checked over a small distance using a 10mm travel DTI.
I have now borrowed a 5mic glass scale and DRO as a standalone system for checking. Assuming it is the ballscrew I was going to do an initial sweep in one direction and check the full travel for the scale check and then check again in small increments and log the variations for the mapping file
My question is , Do i need to do it in both directions as full sweeps or move back and forth?
14 Dec 2018 13:36 #122417
Replied by andypugh on topic How to map a ball screw?
I think I would log all the way from one end to the other in 10mm steps, then step back all the way the other direction.
And then probably repeat this a few times (the number of times being related to how much I had managed to automate the process)
If you can log the DRO values to a PC while running a G-code file that steps backwards and forwards then you could do an infinite number (10) of repeats.
Thinking about it, there might be an argument in favour of making the sample steps an integer multiple of the leadscrew pitch. Or maybe good reasons to _avoid_ that. Certainly something to consider.
20 Dec 2018 22:46 #122661
by Ross77
Replied by Ross77 on topic How to map a ball screw?
Thanks Andy
Averaging lots of samples seems like the best option, I think that's were I'm going wrong buy using too small a sample and introducing more error
Can i log it with linux cnc or would I need a a separate pc and program? any pointers as I've not done any data logging yet.
cheers
cheers
20 Dec 2018 23:09 #122664
You should be able to log with LinuxCNC.
See section 16:
linuxcnc.org/docs/2.7/html/gcode/overview.html#gcode:comments
To get the scale position in to G-code use one of the "analog inputs"
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m66
See section 16:
20 Dec 2018 23:44 #122667
by Ross77
Seems easy enough. famous last words :oD
I'll have a play and see how I get on.
Initial questions are where does "print" print to?
and "The current value of the input is stored in parameter #5399" where is that
21 Dec 2018 00:24 #122668
LOGOPEN, and LOG, (section 16) is the way to go.
(LOG, #<_X> : #5399)
Should do what you want.
- skunkworks
- Thank you received: 148
21 Dec 2018 03:34 #122672
by skunkworks
Replied by skunkworks on topic How to map a ball screw?
I think you can only have 256 points per axis.
03 Jun 2019 16:55 #135761
by AndiT
Replied by AndiT on topic How to map a ball screw?
This seems to be right. The question is, how does linuxcnc handle the positions between these 256 values?
Is there an algorithm that avarages the space between or is it stepwise (linear compensation before/behind the values) until the next value is reached?
Does anybody know something about it? (have not found anything)
03 Jun 2019 19:40 #135786
Linear interpolation
The following user(s) said Thank You: AndiT
30 Jan 2020 00:20 #156126
by Nitram
Replied by Nitram on topic How to map a ball screw?
I have a lathe with both rotary encoders and linear glass scales. Both are physically connected to encoder pins and both are set to home together at the same instant (wired connection of index pulse). Only rotaries are used for position feedback. (Scales are too coarse at 0.005um).
I would like to map the ballscrews with reference to the glass scales.
Can anyone share the G Code which has automated the axis mapping process and writing to a file as described above?
Thanks.
Thanks.
Time to create page: 0.096 seconds
