Coordinate systems exposed in HAL?
31 Jan 2019 02:39 #125368
Replied by rodw on topic Coordinate systems exposed in HAL?
Actually thinking about it, your application might well be a candidate for MPG control for X & Y directions. Scale the MPG output to agree with the external offset count. I'm not sure about the 7i96 but my 7i76e has two MPG inputs. I'm sure Mesa has a daughter card for the 7i96. That would take heaps out of the python gui.
02 Feb 2019 02:37 #125518
by blazini36
Yeah I have a component that handles the Y axis and does some funny business with allowing the ability to ignore a set number of indexes then counting the encoder on the desired index. Problem is when I added a second camera and Y axis #2 it got much more complicated, I couldn't even properly explain what it was supposed to do to the fella that wrote it for me. I wound up writing it myself as a separate hal file since I'm reasonably competent with HAL.
Replied by blazini36 on topic Coordinate systems exposed in HAL?
Writing components is LinuxCNC's best kept secret I think. There are heaps of code examples for the C programmer to follow
github.com/LinuxCNC/linuxcnc/tree/master/src/hal/components
Yes, the external offsets are now part of the master branch base code so its available to any linuxcnc application. Its hardware independent.
02 Feb 2019 02:48 #125519
by blazini36
Not really sure what ya mean there. The GUI is designed to be fully controlled by touchscreen hence the big buttons and arrows. I assume you mean drive the axis by a hardware MPG? The external offset thing I can possibly get with but I'm not a fan of MPG's. I run a 7i76e on my mill, actually I ran the first version of this thing with that same 7i76e and decided it was way overkill with IO, but I stuff new junk on my mill all the time so I swapped em. Currently looking at crazy methods of just making the entire control system as small as reasonably possible.
The more I look at it the more a component makes sense. I just gotta kick my friend in the ass to get it going. I kinda just wanna hand somebody some cash and say "here write this, I don't feel like learning C today".
Anyone know if Linuxcnc supports naming an axis "X1", "X2" etc.? For simplicity sake I've had the 2nd X axis named Y since day one but I've been meaning to do something about that.
Time to create page: 0.250 seconds
