- Configuring LinuxCNC
- Advanced Configuration
- setting up schaublin 125 cnc lathe with carousel toolchanger
20 Oct 2020 20:11 - 20 Oct 2020 20:29 #186740
by trilobyte
Replied by trilobyte on topic setting up schaublin 125 cnc lathe with carousel toolchanger
tom sent me the compiled carousel.so and i replaced it on my computer. after a problem with the file permission it is now working!
big thanks guys!
Peter
big thanks guys!
Peter
Last edit: 20 Oct 2020 20:29 by trilobyte.
20 Oct 2020 20:53 #186748
by inoxix
Replied by inoxix on topic setting up schaublin 125 cnc lathe with carousel toolchanger
PR is here: github.com/LinuxCNC/linuxcnc/pull/964
The following user(s) said Thank You: trilobyte
22 Oct 2020 16:21 #186908
by jlviloria
Replied by jlviloria on topic setting up schaublin 125 cnc lathe with carousel toolchanger
dear, please, could you share the whole sequence of the tool change.
I still can't understand the carrousel component. How do you get the turret out? (Unclamped turret) I don't see any associated pin in what you post.
thanks
thanks
22 Oct 2020 17:54 - 22 Oct 2020 17:56 #186914
by trilobyte
The schaublin 125 toolchanger needs only two pneumatic signals. first the air for the valves etc is turned on, then the movement goes on as long as the second input is on. the movement itself is driven by a pneumatic mecanism.
here's a scematic how the carousel is wired in hal:
PDF
a Video from the chance sequence
if you'd like to see more pictures of the schaublin toolchanger here are picturse made during rework:
Pictures
peter
Pictures
peter
Last edit: 22 Oct 2020 17:56 by trilobyte.
12 Mar 2024 21:11 #295789
by jarcysgru
Replied by jarcysgru on topic setting up schaublin 125 cnc lathe with carousel toolchanger
Witam czy możesz udostępnić pliki konfiguracji zmiany narzędzi tak bym to zrozumiał i uruchomił , bardzo dziękuję i pozdrawiam .
13 Mar 2024 18:33 #295846
by jarcysgru
Can you give me these files for preview This email address is being protected from spambots. You need JavaScript enabled to view it.
Time to create page: 0.177 seconds
