Min,max limit of AXIS using nontrivial kín.
30 Jan 2019 09:21 #125266
by thang
Min,max limit of AXIS using nontrivial kín. was created by thang
With nontrivial kins (like arm robot) MIN_LIMIT and MAX_LIMIT of AXIS in ini are useless, because this numbers depend on position of machine. I could define equation to caculate current min,max limit of machine but is there anyway to udate them when machine is running?
30 Jan 2019 19:49 #125324
by newbynobi
Replied by newbynobi on topic Min,max limit of AXIS using nontrivial kín.
But Joint Limits should be used in Joints mode.
31 Jan 2019 08:16 #125376
by thang
Replied by thang on topic Min,max limit of AXIS using nontrivial kín.
I'm using linuxcnc 2.8, and there are two type limit: Joint limit and Axis limit. here i mention Axis limit that is used when machine is in world mode.
31 Jan 2019 13:02 - 31 Jan 2019 13:13 #125383
by dgarrett
Replied by dgarrett on topic Min,max limit of AXIS using nontrivial kín.
ini hal pins (ini.L.min_limit,ini.L.max_limit, etc.) can
change coordinate soft limits:
Also note:
Ref: linuxcnc.org/docs/devel/html/man/man1/milltask.1.html
The inihal pins cannot be linked or set in a halfile that is
specified by an inifile [HAL]HALFILE item because they are
not created until milltask is started. The inihal pin values
can be altered by independent halcmd programs specified by
[APPLICATION]APP items or by GUIs that support a
[HAL]POSTGUI_HALFILE.
Also note:
The inihal pins are sampled in every task cycle, however,
commands affected by their values typically use the value present
at the time when the command is processed. Such commands include
all codes handled by the interpreter (Gcode programs and MDI
commands) and NML jogging commands issued by a GUI
(including halui).
$ man milltask
Last edit: 31 Jan 2019 13:13 by dgarrett.
31 Jan 2019 17:54 #125417
by thang
This is what i was looking for. I will try if i can update Min,Max limit while machine is in auto mode. Thank you
