custom m code
11 Feb 2019 12:47 #126197
by c123
custom m code was created by c123
Can anyone recommend me a manual for creating custom m codes? I know there are a lot of examples out there but they are all very case specific and none explains how the card gets addressed and where to place bash files.
- Thank you received: 1370
11 Feb 2019 14:12 #126200
Replied by Todd Zuercher on topic custom m code
The documentation is here:
linuxcnc.org/docs/html/gcode/m-code.html#mcode:m100-m199
You save the file to a directory specified in the ini file for your config.
linuxcnc.org/docs/html/config/ini-config.html#_rs274ngc_section
It can also be in the directory specified in the "OPEN_FILE=" path specified in the Display section of your ini file.
For the most part custom M-codes work by directly setting the values of hal pins, such as the hal pin for a parallel port board "parport.0.pin-14-out"
11 Feb 2019 15:01 #126201
by c123
Replied by c123 on topic custom m code
Thanks for the quick reply. i will try that tomorrow.
bernd
bernd
Time to create page: 0.079 seconds
