M19/orient spindle while spindle is running?
06 Mar 2019 14:15 #127884
by dm17ry
M19/orient spindle while spindle is running? was created by dm17ry
trying to mate orient spindle pins to the spindle drive with built-in orient function.
the drive is basically controlled with 3 signals: FWD, REV, ORI. they are level-sensitive. the ORI orient signal has priority over FWD/REV and is honored whether the spindle is rotating or not. while ORI is active the orient-complete ORC is output and spindle is locked. when ORI deasserted, the spindle returns to a previous state.
in linuxcnc (2.8.0pre1 from github) spindle.0.orient is reset to FALSE as soon as spindle.0.is-oriented is signaled, so i am OR'ing spindle.0.orient with spindle.0.locked before feeding to drive's ORI input.
this works unless spindle is rotating when M19 is issued. in this case spindle is stopped, spindle.0.orient is asserted for a brief moment and reset without waiting for is-oriented or signalling any error...
how is M19 supposed to work with the spindle running?
also, the documentation on M19 says: "Spindle orientation requires a quadrature encoder with an index to sense the spindle shaft position and direction of rotation.". i guess this means for use by whoever implements the orientation function?
06 Mar 2019 15:30 - 06 Mar 2019 15:31 #127894
Replied by andypugh on topic M19/orient spindle while spindle is running?
M19 spindle orient sends an orient angle to a HAL pin and toggles some IO pins to handshake that.
It sounds like your spindle drive has a built-in orient to a fixed angle?
If that is the case then your orient is probably better handled by a G-code digital out ( M64 / M65 ) than by M19.
Last edit: 06 Mar 2019 15:31 by andypugh.
06 Mar 2019 16:25 #127900
by dm17ry
Replied by dm17ry on topic M19/orient spindle while spindle is running?
yes, a fixed angle required by the toolchanger.
it was handled by M64/M65 before, i just thought it would be cleaner to use a standard dedicated M word... probably not a very good idea
thanks!
thanks!
