LinuxCNC, MESA & servo-conventional milling
11 Mar 2019 07:59 #128302
by Immutef
LinuxCNC, MESA & servo-conventional milling was created by Immutef
Hey,
I just recently stumbled over the Knuth servo-conventional mill / lathe and beside the ability to do CNC on my milling machine, I miss manual milling a lot. I own a jog pendant, but that doesn't nearly feel like it - turning the handwheels, standing in front of the machine and still beeing able to mill manually, kind of.
I was thinking about enabling servo-conventional milling on my CNC conversion (an Optimum MH25V) - when I converted the machine I bought a 7i76, 7i85, 7i74 and 7i73. After reading the documentation about how many handwheel encoders the 7i73 supports I came to the conclusion that it should be no problem to mount three to four additional handwheel encoders in place where the original handwheels were, just to mimic the manual milling. Am I right?
I probably don't need the features like having three +/- soft limits set per axis, but that might be a nice feature, too, to easy the process. Everything should be doable somewhat easy and without heavy scripting, I just have to wire the handwheel encoders and connect them in LinuxCNC to their very specific axis, maybe adding some potentiometers for feed rates, maybe the Joysticks for rapids, and stuff?
Best regards,
Pierre
Best regards,
Pierre
11 Mar 2019 11:10 #128305
by pl7i92
Replied by pl7i92 on topic LinuxCNC, MESA & servo-conventional milling
look here this tread is exactly what you like to do on the 7i73
11 Mar 2019 11:23 #128307
by Clive S
Did you miss the link out?
Replied by Clive S on topic LinuxCNC, MESA & servo-conventional milling
11 Mar 2019 13:36 #128334
Yes. I have a 7i73 in the apron of my lathe, and have MPGs in (roughly) the original handwheel positions.
photos.app.goo.gl/RQZPDWeU8b353c337
Replied by andypugh on topic LinuxCNC, MESA & servo-conventional milling
11 Mar 2019 13:38 #128337
by Immutef
Replied by Immutef on topic LinuxCNC, MESA & servo-conventional milling
Woah, what a monster of a machine! That looks exactly like what I want. Thanks for the replies so far!
- Mike_Eitel
- Thank you received: 185
11 Mar 2019 18:16 #128365
by Mike_Eitel
Replied by Mike_Eitel on topic LinuxCNC, MESA & servo-conventional milling
On my 4 axis I have 4 handwheels. Not more selector on the wrong axis
Based on 7i76e and 7i73. Works like a charm.
11 Mar 2019 18:32 #128368
by Immutef
Have you ever removed the cap of such a handwheel encoder? I wonder if its a big deal to attach a real [big] handwheel, maybe the original ones from the mill [120mm diameter].
11 Mar 2019 19:47 #128377
by Clive S
I turned 120 rings and fitted them over the hand wheels with a bit of epoxy.
Time to create page: 0.250 seconds
