7i80hd+7i52s+7i44+7i29?
16 Mar 2019 20:44 #128770
by 3D-Master
7i80hd+7i52s+7i44+7i29? was created by 3D-Master
Hello,
i was wondering if it would be possible to use a 7i29 (or 7i27), 7i44, 7i52s with the 7i80hd? Also can i use the encoder ports on the 7i29 like the ports on the 7i52s meaning i would have 8 PWM Axes and highspeed Encoder ports? I am planning on maybe getting an 7i27 or 7i29 to be able to use a more powerful spindle motor but mainly the reason is because i need 7 axis (5 axis cnc + spindle motor + toolchanger motor).
thanks
thanks
17 Mar 2019 02:15 - 17 Mar 2019 02:18 #128795
Yes, that should all work and you would have 8 available encoders
Replied by PCW on topic 7i80hd+7i52s+7i44+7i29?
Hello,
thanks
Last edit: 17 Mar 2019 02:18 by PCW.
The following user(s) said Thank You: 3D-Master
Time to create page: 0.223 seconds
