- Configuring LinuxCNC
- Advanced Configuration
- All of a sudden a problem in my SIM setup to test at home code
19 Mar 2019 22:20 #129012
STL zip fairly efficiently.
Replied by andypugh on topic All of a sudden a problem in my SIM setup to test at home code
I will when I am at my computer. The STL files are to big to upload here. I will make a zip with all other files
20 Mar 2019 19:11 #129095
by Marcodi
Replied by Marcodi on topic All of a sudden a problem in my SIM setup to test at home code
HI,
As requested here are the complete files. So the stl files need to go in the config folder. and the vismach "5stefgui" needs to go into the /usr/bin folder, but i guess you guys no this
Hope someone finds out why this thing isn't working anymore.
Thanks in advance
Thanks in advance
21 Mar 2019 01:14 #129132
Which INI file? sim-axis-1 contains all the usual ones, which has your GUI in it?
21 Mar 2019 18:04 #129207
by Marcodi
Oeps sorry,
The 9axis one
Stephane
The 9axis one
Stephane
21 Mar 2019 18:39 #129210
21 Mar 2019 18:48 #129211
With my installation I have made it work by changing the subroutine path to include the home folder of the ini (which is where the tool-change.ngc and other files are
(It's the :./ at the end)
SUBROUTINE_PATH = ../../nc_files/:./
21 Mar 2019 21:54 #129222
by Marcodi
HI Andy,
Thanks for trying. It seems something else is wrong in my system. For me the changes in path resulted in same error.
I did however spent the past 7 hours trying, without results, so i started over from scratch and i got it to work again. I still don't see any difference in my ini files between old and new. Nor did i change anything to any of the vismach files. But it works again after making a new sim folder starting from the base 9 axis sim. I guess i must have messed up some other file somewhere in the stack without having ever realized it.
Thanks anyway for your superb enthousiasm for helping others!!!
Soon i will be adding a topic with a postprocessor for solidcam and a XYZA machine. ( rotary attachment on the bed, like a lot of us might have ) It has been written for linuxcnc.
Time to create page: 0.245 seconds
