running linux cnc with no display - some questions
02 Apr 2022 14:55 #239072
by gmr
Replied by gmr on topic running linux cnc with no display - some questions
For the next person who finds this post, in 2.8.2 (at least), you can write
DISPLAY=dummy
In the [DISPLAY] section of the ini file.
DISPLAY=dummy
07 Apr 2022 20:51 - 07 Apr 2022 20:51 #239586
Replied by andypugh on topic running linux cnc with no display - some questions
DISPLAY = halui
Also works.
Also works.
Last edit: 07 Apr 2022 20:51 by andypugh.
15 Apr 2023 17:54 #269137
by iforce2d
Replied by iforce2d on topic running linux cnc with no display - some questions
fwiw I'm trying this with 2.8.4 and if I set "DISPLAY = halui" I get this error:
To avoid the error it seems I need to comment out this line further down:
Alternatively, the "DISPLAY = dummy" suggested above works as a one-line change.
HAL: ERROR: duplicate component name 'halui'
HALUI: ERROR: hal_init() failed
emc/usr_intf/halui.cc 2299: hal_init error
HALUI = halui
04 Jul 2023 17:47 - 04 Jul 2023 18:01 #274762
by iforce2d
I have been doing some experimenting in this area recently so I thought I would share a bit. My goal is to have a completely headless installation that I can operate with just physical buttons, encoder for jogging etc. I will be running the same job over and over so the file only needs to be specified very infrequently. Initially I will have to SSH in to start it and set the file of course.
To start LinuxCNC running with no display and then be able to close out the terminal leaving it running, set the [DISPLAY]DISPLAY value to 'dummy' in your .ini file. Then you can make a copy of the startup script file /usr/bin/linuxcnc (I copied it to /usr/bin/linuxcnc-headless) and comment out a couple of lines right near the end. Commenting these out will skip the step where it would normally wait for user input to continue, and then also skip the shutdown procedure:
ffs.... what is wrong with this forum??!?!?!?!?!! EVERY time I post here (especially to edit an existing post) the format gets all messed up or something disappears!!! It has been like this for years. This time I had a whole explanation written out and now most of it is gone, and right now I cannot be bothered writing it all again sorry. I will just put the video link and the github link, it might explain the overall idea well enough, let me know if anything is not clear and maybe I can answer after I calm down.
github.com/iforce2d/linuxcnc-gcode-server
Last edit: 04 Jul 2023 18:01 by iforce2d. Reason: Forum trolling me yet again, deleted half my post
- Thank you received: 5957
04 Jul 2023 17:54 #274763
Replied by tommylight on topic running linux cnc with no display - some questions
Make a new post and add the video again.
Thank you.
Thank you.
Time to create page: 0.117 seconds
