Best practices/Tool Touch Off/Material Origin
- buckaboobob
24 Apr 2019 19:09 #131786
by buckaboobob
Best practices/Tool Touch Off/Material Origin was created by buckaboobob
I Added a touch off plate as I started doing things that required a tool change and that's when I started to see things start to go all weird with the coordinate's... So I have done a fair amount of reading and have an understanding of why things are getting all weird with coordinates when I do a touch off..
So this is my understanding... If I am deviating from best practices or being more complicated than I need to be let me know.
Set Home (XYZ) - Sets the absolute machine coordinates.. (These should be near a limit of your machine depending on min/max travel)
Material Origin - MDI G10 L2 P1 X0Y0Z0 (Would set the G54 XYZ Based on the current tool length)
Now this is where It get s a bit murky in my head... When i go to change a tool that will obviously have a different length what is the best practice coordinate system to set the new tool length...
It looks like I should be using a G43.1 (I am just using a trim router so repeatability of tool changes is not possible)
But It doesn't appear that it can be set based on current tool position and I would need to touch off the current tool switch to absolute coords move to a known location change the tool move back above the touch plate then run a touch off again and calculate the offset and set it with a G43.1 Z(offset)
Or
simply change the tool... use a touch plate and set MDI G10 L2 P1 Z0(compensated for the height of the touch plate)?
It seems to me to be poor practice to change the z origin when changing a tool as that origin point has not changed.
Or
- Thank you received: 1369
24 Apr 2019 20:40 - 24 Apr 2019 20:42 #131793
Replied by Todd Zuercher on topic Best practices/Tool Touch Off/Material Origin
If this is a manual tool change machine with non repeatable tool lengths, (such as a collet spindle router) there is not much point in even trying to use the tool table or tool length offsets. Simply re touch off the Z with the new tool installed using G10L2P1Z0. (if you leave out X and Y they will not be changed)
For example here is the sub routine I use to probe the Z and set the depth on a router, using a simple conductive touch plate. The surface probed will be set to G54 Z0.
o<probe-z> sub
M66 E0 L0
#1= 0.02 (probe thickness)
f10
g38.2z-1.0
g53 g0 z0.0
#2=#5063
(debug, #5223 Old G54 Z offset)
#3=[#2-#1]
(debug, #3)
#4=[#5223+#3]
(debug, #4 New G54 Z offset)
G10 L2 P1 Z[#4]
o<probe-z> endsub
Last edit: 24 Apr 2019 20:42 by Todd Zuercher.
- buckaboobob
24 Apr 2019 21:00 #131795
by buckaboobob
Replied by buckaboobob on topic Best practices/Tool Touch Off/Material Origin
That's the answer i was expecting to get... I was hoping to hear of a better practice method of doing it...
I am sure one day i'll decide to setup more than one work piece and use G55 or another coordinate system and forget that my touch off is only setting G54... I was hoping there was a implemented way to set the tool length so that it would be applied to all work G5X coordinate systems... Dunno if I will ever be running more than work piece at a time that I would need to worry about it but I thought I would just ask and see if there was a better way to do it.
Thanks for your reply... much appreciated!
25 Apr 2019 02:46 - 25 Apr 2019 12:17 #131826
You can specify the coordinate system specifically with the P term such as G10L2P2 for G55 or whatever one is active with P0.
Last edit: 25 Apr 2019 12:17 by Todd Zuercher.
25 Apr 2019 09:49 #131844
Todd, thanks perfect timing, I was trying to get my head around this earlier today. Thank you very much
Replied by rodw on topic Best practices/Tool Touch Off/Material Origin
25 Apr 2019 14:07 #131855
by pl7i92
Replied by pl7i92 on topic Best practices/Tool Touch Off/Material Origin
the G10 L2 will not reload the G-code so you need to press reload
or you add a User Mcode that calls axis-remote reload
so the DRO is in sync
Time to create page: 0.127 seconds
