Bitfile 6i24-25 with 7i33, 7i37TA and 7i44
- Teppichfliese
12 May 2019 15:34 #133563
by Teppichfliese
Bitfile 6i24-25 with 7i33, 7i37TA and 7i44 was created by Teppichfliese
Hello,
My Name ist Jens and live in Northern Germany. Treid to create a bitfile for my Milling Machine. Got the Mesa Boards 6i24-25 with 7i33, 7i37TA and 7i44. My backround is mechanical stuff, so im not really good in this programming Things.
Maybe someone can hilp me in this case?
Thank you
Jens
Thank you
Jens
12 May 2019 15:54 #133565
Replied by PCW on topic Bitfile 6i24-25 with 7i33, 7i37TA and 7i44
5i24_25_svss8_8.bit
would be the correct bit file
7I33 on P4
7I37 on P2
7I44 on P1
7I33 on P4
7I37 on P2
7I44 on P1
The following user(s) said Thank You: Teppichfliese
12 May 2019 15:56 #133567
by DanielCNC
Replied by DanielCNC on topic Bitfile 6i24-25 with 7i33, 7i37TA and 7i44
i used this tutorial (german) to create mine for a 7i92m :
was quite usefull, now i´m stuck at the hal and the ini file:)
good luck
Daniel
good luck
Daniel
- Teppichfliese
13 May 2019 11:05 #133633
by Teppichfliese
Replied by Teppichfliese on topic Bitfile 6i24-25 with 7i33, 7i37TA and 7i44
Hello together,
many thanks for your help. How do you know that? Is there anywhere a list, where is writen, Which daughter Card works with this bitfile?
@Daniel: I know the channel from talla and don´t know how many times I watched it
Really, Thnak you.
Best regards
Jens
Really, Thnak you.
Best regards
Jens
13 May 2019 14:18 #133641
Unfortunately for the odder ones, you really have to check the pinout
Either the .pin file if its available or the source file
Time to create page: 0.274 seconds
