Move to toolchange postion
- Skidloaders1
18 May 2019 14:47 #134188
by Skidloaders1
Move to toolchange postion was created by Skidloaders1
Good day all
Have mill with air cylinder for toolchange.
Like to have Z axis move to home/limit switch when pushing a button, retract a little and activate air cylinder for as long as push button is activated. regards Wilfried
18 May 2019 15:19 #134190
by pl7i92
Replied by pl7i92 on topic Move to toolchange postion
hi
first you can define this position in the ini
then Linuxcnc got 4 preprogrammed position on G-code
www.linuxcnc.org/docs/html/gcode/g-code.html#gcode:g30-g30.1
so there are many ways to do it
- Skidloaders1
18 May 2019 16:01 - 18 May 2019 18:03 #134199
by Skidloaders1
Replied by Skidloaders1 on topic Move to toolchange postion
Sure, know about G30 etc.. but how do i get it to listen to a pushbutton?
example
net toolchange <= hm2_5i20.0.gpio.054.in_not => halui.jog.selected.plus ??????
how to select ???
example
how to select ???
Last edit: 18 May 2019 18:03 by Skidloaders1.
18 May 2019 19:16 #134211
by bevins
The following user(s) said Thank You: Skidloaders1
