- Configuring LinuxCNC
- Advanced Configuration
- MESA 7i96+7i76 : How to add 4 PWM and to connect 3 SSERIAL daughterboards ?
21 May 2019 14:59 #134485
by nbremond
Replied by nbremond on topic MESA 7i96+7i76 : How to add 4 PWM and to connect 3 SSERIAL daughterboards ?
Thanks a lot for your replies.
And, instead of using dir/step output I need to control mu steppers, what about using 1 of the 6 GPIO outputs of the 7i96 for TX, and one of the 7i96 GPIO inputs for RX ?
What do you think ?
What do you think ?
21 May 2019 15:08 #134486
by nbremond
BTW, Thanks a lot PCW for the advise about bitfiles ! And I am interested to know more about this read_request function... What is this doing ?
For the SSerial interface, if I understand correctly, using the Encoder intput and Step/Dir output will directly give me différential TX+ TX- and RX+ RX- signals with no need for an external RS485/RS422 transceiver ?
Is that correct ?
It should be the same for the regular GPIO outputs of the 7i96 tTB3, pin 13 to 24) as they are differential outputs...
Is that correct ?
21 May 2019 15:16 - 21 May 2019 15:18 #134489
Replied by PCW on topic MESA 7i96+7i76 : How to add 4 PWM and to connect 3 SSERIAL daughterboards ?
Unfortunately the power outputs and isolated inputs are about 1000 times too slow for SSerials 2.5 Mbaud data rate, Much better at what they were designed for, driving relays/solenoids and sensing limit switches
edit
The isolated outputs are not differential, they are 2 connections to a isolated MOSFET switch
edit
Last edit: 21 May 2019 15:18 by PCW.
The following user(s) said Thank You: nbremond
21 May 2019 15:17 #134490
by nbremond
Got it. Thanks !
22 May 2019 11:09 #134565
by nbremond
Thanks for your help.
I am going to go with software PDM for the heater control as you suggested. It make sens.
For the SSerial board, by connecting the "Enable" input of the stepper drivers to 2 GPIO, I'll be able to connect 2 stepper drivers to one DIR/STEP output. This will free one DIR/STEP output for the 2 TX signals to SSerial daughterboards, and I'll use the ENCA and ENCB inputs as 2 RX as you suggested. With the SSerial interface that is already on the 7i96, I'll have the 3 serial interfaces I was looking for.
I'll have to generate the corresponding bitfile (following your adives, should be no big deal... or I'll ask few questions on this forum) and I still have to make the wiring of the CNC-3D printing machine. It may take few weeks daught as I have my job and other projects running.
Best regards.
Bernard.
Best regards.
Bernard.
- Thank you received: 5933
23 May 2019 01:00 #134632
Replied by tommylight on topic MESA 7i96+7i76 : How to add 4 PWM and to connect 3 SSERIAL daughterboards ?
7i96 should have at least 1 25pin header so you can add a 7i74 and have 8 more sserial.
PCW can confirm that as I never used a 7i96, but used plenty of 7i74.
23 May 2019 04:39 #134663
by nbremond
Yes the 7i96 has 1 25pin header, but I already use it for a 7i76 daughterboard. This is why I'll need a workaround...
24 May 2019 01:26 #134763
Oh well, to late but a 7i76E would have been perfect. Chugging along, no turning back now.
