- Configuring LinuxCNC
- Advanced Configuration
- Pin 'halui.estop.is−activated' does not exist, when clearly it does
12 Jul 2019 05:50 - 12 Jul 2019 05:52 #139143
by JetForMe
So, yeah. Not a file encoding issue. But I copy-pasted it from the documentation page, which actually has "−" in the HTML source, which ends up rendering a 3-byte UTF8 character, and not a hyphen. It probably should be "‐", but really, the source files should be encoded as UTF8 and just typed directly.
Thank you for noticing. I was editing the file in BBEdit on a Mac and it displayed it as a hyphen-looking thing, and I couldn't see anything amiss.
Replied by JetForMe on topic Pin 'halui.estop.is−activated' does not exist, when clearly it does
When I looked at your postgui file I see this on line 13 :
net e-stop-active <= halui.estop.is−activated
Chris M
Last edit: 12 Jul 2019 05:52 by JetForMe.
12 Jul 2019 05:58 #139144
Replied by cmorley on topic Pin 'halui.estop.is−activated' does not exist, when clearly it does
So that fixed the problem? - excellent - ya sometimes a new set of eyes...
Never cam across that error before.
Chris M
Chris M
12 Jul 2019 07:14 #139151
by JetForMe
Yup, totally fixed the problem. Not the problem inherent in the HTML docs, but the problem in my HAL file
12 Jul 2019 07:19 #139153
by pl7i92
Replied by pl7i92 on topic Pin 'halui.estop.is−activated' does not exist, when clearly it does
it is highly recomented to set your editor to utf-8
12 Jul 2019 07:23 #139155
by JetForMe
My editor *is* UTF-8. It can be argued that's what caused the problem. When I copied the pin name from the web docs, it was wrong, but it wasn't visibly wrong in a UTF-8 editor. An ASCII-only editor would've shown it as a set of garbage characters, as Chris M pointed out.
12 Jul 2019 08:56 #139159
Replied by rodw on topic Pin 'halui.estop.is−activated' does not exist, when clearly it does
Which editor are you using? You can't go past Geany.
I am always very wary copying and pasting from a web site I often paste it into a ascii text editor before using it if I have any doubt.
13 Jul 2019 00:51 #139222
by JetForMe
It's the LinuxCNC website! It's just generated badly (either the source material or the HTML generator is wrong).
13 Jul 2019 07:13 #139235
by pl7i92
you shoudt prefer the pdf Documentation on all stuff
as best you can use it direct on the mashine side
15 Jul 2019 13:59 - 15 Jul 2019 14:01 #139430
FWIW I agree with you here. Code snippets in the docs should work.
Which page of the html docs did you get it from?
Replied by andypugh on topic Pin 'halui.estop.is−activated' does not exist, when clearly it does
Last edit: 15 Jul 2019 14:01 by andypugh.
Time to create page: 0.097 seconds
