- Configuring LinuxCNC
- Advanced Configuration
- How to move joints of a new robot to verfiy it's motions?
19 Sep 2019 20:59 - 19 Sep 2019 21:00 #145626
I think in that sim you can switch between cartesian and joint jogging (Machine menu or $ shortcut). Which might answer one of your questions.
G-code -> interpreter -> TP -> TC -> kinematics -> HAL.
linuxcnc.org/docs/html/code/code-notes.html
It's something like that. I confess I have never needed to know as I don't own a robot.
I think it is actually something that is entirely determined by the kinematics file. That basically gets the XYZ ABC numbers directly, and transforms them in to joint angles, so the ABC can be interpreted in a number of ways.
linuxcnc.org/docs/2.8/html/motion/5-axis-kinematics.html
Replied by andypugh on topic How to move joints of a new robot to verfiy it's motions?
sim-axis-Vismach-puma-puma560 is really neat.
G-code -> interpreter -> Genserkins -> hal pins ?
There's a trajectory planner in there somewhere too right?
The abc. Is it a Euler sequence? 1st a about x, then b about y, then c about z? I've worked with kukas where a is the 1st rotation about z, then b about y, finally c about x.
Last edit: 19 Sep 2019 21:00 by andypugh.
Time to create page: 0.060 seconds
