How to read errors on Halscope
27 Sep 2019 21:29 #146434
by Scot
How to read errors on Halscope was created by Scot
Hello all,
So I've been fiddling and learning how to use Halscope if you haven't seen my latest posts. And I'm a bit confused as to what I'm looking at and what I'm trying to get to happen through adjustment, other than tuning, that is. Of course the goal is to get the servo to tune to the point where there is an instantaneous move to ramp up, a flattening at it's top commanded speed, then a drop back to zero where it stops, all with the encoder counting the pulses and keeping up with the commanded position as closely as possible, so as to not overshoot and waver at either the beginning, middle or end. I understand the theory. But I'm trying to understand what exactly I'm trying to adjust and by how much, to make this happen accurately.
I understand that as you increase and decrease the gain on the trace that you're sourcing on Halscope, it changes the ability to see error. And I understand that this scale change translates to real world measurements as read through the encoder. I get that part, although not completely. But am I looking for the difference between the high and low points of the trace from it's horizontal starting line to determine the error the scale I'm tracing the signal from? Am I looking at the difference between how far apart the horizontal start line is from where it goes back to it's zero point? Because sometimes, the trace starts horizontally at one point,then it wavers and where it flattens, the trace is at another horizontal level, all together.
Maybe I'm not using the right terminology? Attached is the latest screenshot I'm getting with the calibration menu settings on the left.
Keep in mind, I'm a newbie. Even if there is a strong, vernacular, tutorial about the language I should use, that would be very helpful.
Thanks in advance,
Scot
Thanks in advance,
Scot
- Thank you received: 1370
28 Sep 2019 01:46 #146447
Replied by Todd Zuercher on topic How to read errors on Halscope
Your screen shot didn't show up.
The trace of the following error on the scope is simply how far the encoder's feedback position differs from the commanded position. For a move in the positive direction, when the following error trace is above the 0 line it represents how far the encoder is lagging behind the commanded position, when the trace is below 0 it is ahead of the commanded potion.
In your tuning you are striving to minimize the following error. (Keep the trace as close to zero as possible all the time.)
28 Sep 2019 07:37 #146467
by pl7i92
Replied by pl7i92 on topic How to read errors on Halscope
you may need to run some test Gcodes
there are some provided at gnipsel
as well thy the cycles of treading as well as the Drillcycles
- Thank you received: 5957
28 Sep 2019 07:46 #146470
Replied by tommylight on topic How to read errors on Halscope
No, do not try to run gcode on a not tuned machine, that might end up badly.you may need to run some test Gcodes
