- Configuring LinuxCNC
- Advanced Configuration
- Best approach to hold the feed depending on signal input
- mindoverflow
12 Oct 2019 23:13 #147759
by mindoverflow
What is the best way to hold the feed depending on a sensor output? (could it be the same as an external pause/resume button?)
You can imagine it as a knife or stamp hitting the material being fed, the event happens about 600 times per second.
Thank you.
Thank you.
13 Oct 2019 02:14 #147772
Replied by cmorley on topic Best approach to hold the feed depending on signal input
18 Oct 2019 23:42 #148244
Replied by andypugh on topic Best approach to hold the feed depending on signal input
Or possibly motion.adaptive-feed
