5axiskins tool offset
25 Nov 2023 19:05 #286486
Replied by Aciera on topic 5axiskins tool offset
You need to the lines for the kinematic component and set your pivot length:
loadrt sum2 names=pivotsum
addf pivotsum servo-thread
setp pivotsum.in0 <your pivot length here>
net :tool-len <= motion.tooloffset.z => pivotsum.in1
net :pivot-len <= pivotsum.out => 5axiskins.pivot-length
- choqui2010
25 Nov 2023 19:35 #286490
by choqui2010
Replied by choqui2010 on topic 5axiskins tool offset
ERROR.!!
./MARLON.hal:113: Signal 'pivot-len' can not add I/O pin '5axiskins.pivot-length', it already has OUT pin 'pivotsun.out'
26 Nov 2023 02:32 #286523
Please attach your hal file.
- choqui2010
28 Nov 2023 13:40 #286702
by choqui2010
Hello, sorry for responding late, these days I was out of the machine.
I will attach the INI and HAL files
- choqui2010
28 Nov 2023 13:45 #286703
by choqui2010
28 Nov 2023 18:30 #286716
Not sure where your error message comes from as '5axiskins.pivot-length' is not used in your hal file. Do you have anything in the 'custom.hal' file or something in the postgui hal files?
- choqui2010
29 Nov 2023 16:09 #286798
by choqui2010
actually the message would be like this.
ERROR.!!
./MARLON.hal:113: Signal 'pivot-len' can not add I/O pin 'lupakins.pivot-length', it already has OUT pin 'pivotsun.out'
ERROR.!!
29 Nov 2023 16:28 #286799
the only line in your hal and ini that contains 'lupakins.pivot-length' is this one in your hal file, which seems to be the one it complains about.
net :pivot-len <= pivotsum.out => lupakins.pivot-length
This would suggest that you have some other hal file in your config folder that also contains a similar line. If you are unsure then please compress your entire machine config folder and post that here so I can have a look at all the files in the config.
- choqui2010
01 Dec 2023 10:40 #286958
by choqui2010
01 Dec 2023 19:20 #286985
In the [HAL] section of your ini file remove this line:
HALCMD = setp lupakins.pivot-length 227
set your pivot-length in your hal file:
setp pivotsum.in0 110
