doubt on tool setter wiring
08 Mar 2021 11:00 #201412
by sibelius
Replied by sibelius on topic doubt on tool setter wiring
Actually i just realize that I made a mistake in respect of what I want to do.
The yellow wire should be terminate in a pin above the probe input pin and set hal as a limit switch.
That's what I mean in new drawing.
Regards,
V.
Regards,
V.
- gardenweazel
- Thank you received: 5
17 Sep 2023 14:06 #281010
by gardenweazel
Replied by gardenweazel on topic doubt on tool setter wiring
Folks,
Can anyone confirm that the final diagram is correct for this tool setter?
I'm under the assumption that a resistor is not needed for the Mesa 7i76E?
Regards
Regards
20 Sep 2023 00:04 #281197
Replied by andypugh on topic doubt on tool setter wiring
The resistor would seem superfluous to me, assuming that you are using a Mesa card with 24V-safe inputs.
The following user(s) said Thank You: gardenweazel
27 Oct 2023 22:15 #283925
by sibelius
I wired the tool setter according to the drawing and it works for me
Time to create page: 0.382 seconds
