- Configuring LinuxCNC
- Advanced Configuration
- additional probe inputs or configuration for tool height sensor ???
21 Sep 2023 00:09 #281265
by GeramyL
Replied by GeramyL on topic additional probe inputs or configuration for tool height sensor ???
not to beat a dead horse, but. It would be nice to tie in outputs to the tool setter, is there a way to say when probe mode is turned on we set output on a pin? Which I can then set as the voltage for my tool setter and then when input is triggered and after it does the tool height process I can have that output turned off again so the tool height is no longer powered and no false trips will happen?
21 Sep 2023 04:40 #281277
by phillc54
Replied by phillc54 on topic additional probe inputs or configuration for tool height sensor ???
You could possibly use the HAL pin motion.motion-type
linuxcnc.org/docs/html/man/man9/motion.9.html#MOTION%20PINS
21 Sep 2023 18:25 #281325
by GeramyL
so value 4: Tool change would work right? How would I do a comparison if motion-type == 4 output 1 else 0?
29 Sep 2023 12:35 #281856
by looping
Replied by looping on topic additional probe inputs or configuration for tool height sensor ???
have a look here :
forum.linuxcnc.org/qtvcp/49934-qtdragon-...d-remap-g38-2#279717
Time to create page: 0.316 seconds
