How to add inputs and outputs to iocontrol
19 Jun 2009 06:53 #445
by kreshnik
How to add inputs and outputs to iocontrol was created by kreshnik
Hi everybody.
I have a problem and I don't know how to solve it.
I'm using EMC with a 3 axis machine. However I need to add additional inputs and outputs (1 bit).
I don't know how to do it easily.
I tried to follow the implemention of the output "lube" and I succeeded to create one output. To do this I had to modify 10 source code files and I had to re-compile EMC. I'm not sure it's the right way to do it and I need your advice.
Thank you in advance for your help.
Kreshnik
PS: I tried to add 20 output. EMC craches with the message : "CMS:(emcStatus) Message size of 10900 exceeds maximum of 10180"
Kreshnik
19 Jun 2009 13:11 - 19 Jun 2009 13:12 #448
by BigJohnT
Replied by BigJohnT on topic Re:How to add inputs and outputs to iocontrol
What version of EMC are you running?
What are the inputs and outputs for? Perhaps there might be an easier way...
Last edit: 19 Jun 2009 13:12 by BigJohnT.
19 Jun 2009 13:25 #449
by kreshnik
Replied by kreshnik on topic Re:How to add inputs and outputs to iocontrol
I'm running EMC 2.2.5.
I need to add outputs to control some light switches.
Thanks for your help
19 Jun 2009 13:58 - 19 Jun 2009 13:59 #450
by BigJohnT
What triggers the outputs?
Are the outputs on the parallel port card?
Can you tell us what your trying to do?
Last edit: 19 Jun 2009 13:59 by BigJohnT.
19 Jun 2009 14:24 #451
by kreshnik
I have a Motenc PCI card.
I just want to command 3 lights with on-off signals.
19 Jun 2009 15:11 #452
by BigJohnT
If your wanting to do this with G-Code look at M100-199
www.linuxcnc.org/docview/html//gcode_main.html#sec:M100-to-M199:
19 Jun 2009 15:21 #453
by kreshnik
Thanks for your help.
But I am using TCL and I need to activate an output when I push a button.
19 Jun 2009 16:08 #454
by BigJohnT
By "TCL" do you mean your using the TKEMC interface or is it another interface?
A physical button or a button on the screen that you push with a mouse click?
Have you looked at pyVCP?
19 Jun 2009 16:17 #455
by swpadnos
Replied by swpadnos on topic Re:How to add inputs and outputs to iocontrol
kreshnik,
There are several ways to control a HAL output.
First, take a look at how halshow does it. If I remember correctly, it basically exec's halcmd, and pipes commands to it. Using this method, you can send "setp motenc.0.whichever_bit 1" (or 0) to turn a bit on and off.
Second, if you're not required to use TCL, you can make a simple pyvcp panel with a few buttons. Connect these buttons directly to the motenc pins in HAL, and you'll have a GUI that lets you twiddle bits directly. Use checkboxes if you toggles rather than momentary contacts.
You can also control some outputs using G-code, so you could (in some circumstances) use an MDI command to control them. This is probably not a good idea, but I figured I'd mention it anyway You can't use this method while a G-code program is running, for example.
- Steve
- Steve
22 Jun 2009 07:05 #468
by kreshnik
Thanks for your help guys
to BigJohnT :
I'm already using MINI interface which is coded in TCL language. The interface is already done.
to swpadnos :
The interface is already done in TCL. How can I access directly to the motenc pins ?
to BigJohnT :
to swpadnos :
Time to create page: 0.123 seconds
