- Configuring LinuxCNC
- Advanced Configuration
- Need help with the orient component for spindle activation (M19)
16 Mar 2022 19:57 #237490
by jpg
Replied by jpg on topic Need help with the orient component for spindle activation (M19)
and it is always the same value that are ingest for ORIENT, no I do not think that it is problematic for the continuation, it is to have the 0 on a lathe and perhaps a milling machine (it has 100 years); in any case, I would like to thank you for your work on the demo VISMACH and more recently on this project, thank you again, Andy!
18 Mar 2022 17:02 - 18 Mar 2022 17:05 #237652
by jpg
Good evening, so that "ORIENT" is not more allergic with certain values, I replaced that:
setp near.0.difference 0.0005
by
setp near.0.difference 0.0006
by
Last edit: 18 Mar 2022 17:05 by jpg.
- leandrocontarini
22 Mar 2023 00:41 #267268
by leandrocontarini
Replied by leandrocontarini on topic Need help with the orient component for spindle activation (M19)
Could you post how all the files turned out, from the fuzzy orientation you made? the ini file and the hal files. I tried here with the ones you described, but I couldn't.
23 Mar 2023 12:07 #267356
by jpg
hello, I try to post you the complete configuration tonight, it works very well (not yet on the machine -test empty-) try also on version 2-8-4
- leandrocontarini
23 Mar 2023 22:06 #267381
by leandrocontarini
Thanks friend, I'll wait.
24 Mar 2023 10:06 #267402
by jpg
hello, sorry, I didn't have time last night, tonight you have it
The following user(s) said Thank You: leandrocontarini
24 Mar 2023 20:40 - 24 Mar 2023 20:53 #267422
by jpg
Last edit: 24 Mar 2023 20:53 by jpg.
The following user(s) said Thank You: akb1212
- leandrocontarini
01 Apr 2023 10:06 #268011
by leandrocontarini
good morning my friend
Are you sure these files work?
It seems to be different from the other posts.
I tried here, but it didn't work.
I am using version 2.8.3 and 2.8.4.
05 Apr 2023 10:54 #268327
by jpg
hello, yes very good, works on and created on the 2-7-15 and tested also on the 2-8-2 maybe you have only one control card, then you have to "comment" some lines (#) such as parport 1 if you have no MPG
Time to create page: 0.092 seconds
