Lathe with C axis and some challenges...
07 Sep 2022 22:04 #251444
Replied by andypugh on topic Lathe with C axis and some challenges...
If you made the spindles C and B you could put elegant twists in your work
Note that you can use M19 for any of your spindles individualy. But that doesn't give you coordinated motion.
Still, it might be more flexible to have the two spindles as separate axes.
09 Sep 2022 14:05 - 09 Sep 2022 14:16 #251550
by jpg
Replied by jpg on topic Lathe with C axis and some challenges...
Hello everyone, I have several questions: up to what speed (rpm) in C axis mode, while being indexed? 500, 1000 rpm? and is it possible with a VDF as a spindle? like here,using the ORIENT component?
See 3.35
See 3.35
Last edit: 09 Sep 2022 14:16 by jpg.
09 Sep 2022 16:24 #251553
by Henk
Replied by Henk on topic Lathe with C axis and some challenges...
Are you referring to the eliptical turning or spindle orientation/position control.
Excentric or odd shape turning is possible with external offsets. Search the forum for that.
09 Sep 2022 16:30 #251554
by jpg
I have seen this before, but the c-axis seems to be more recommended
17 Sep 2022 18:48 #252192
If I was wanting to machine ovals, then I would use offsets calculated from spindle position. In fact I have.
The following user(s) said Thank You: tommylight, besriworld
- smc.collins
- Thank you received: 109
29 Apr 2023 00:06 #270149
by smc.collins
Replied by smc.collins on topic Lathe with C axis and some challenges...
can you attach your INI file. I am modifying my spindle hal component to manage this and other things. I'd like to see how your INI is configured.Didnt attache the hal file...
29 Apr 2023 19:20 #270225
by Henk
Hi. Sorry. I didn't get (or see...) a notification of your post.
I'll upload my config here tomorrow.
Henk
Henk
The following user(s) said Thank You: smc.collins
30 Apr 2023 05:39 #270291
by Henk
HI
This is the INI and hal files relevant to the spindle and the tool turret, as well as the .comps that i wrote to handle the spindle-C axis changes and the tool changer.
The tool turret indexing as well as the live tool is driven by the same servo motor.
I have not invested in live tools to fit in the VDI30 turret yet, but i have tested the functions on the machine and it seems to work OK.
The spindle drives are controlled in analog velocity mode (0-10v and CW/CCW signals) for spindle functions and the C-axis positioning control is done in step/dir mode, velocity command and the position loop closed by linuxcnc PID .
Its been a while since i tinkered with this......
Henk
Henk
- smc.collins
30 Apr 2023 11:59 - 01 May 2023 02:12 #270304
by smc.collins
thank you, I'm integrating a bunch of functions into my spindle component. i just wanted to see a functional c axis to work from. this is awesome, thank you. My C axis will be my spindle drive with velocity +-10v style, it has servo functionality. So what I was trying to figure out was how to configure this as a rotary axis. Is it just like any other axis ? how do I set up the encoder to it reads in degree in the ini ? or does it know ?
Last edit: 01 May 2023 02:12 by smc.collins.
02 May 2023 10:54 - 02 May 2023 11:34 #270472
by jpg
Hello, your C axis is well as I think your spindle motor (asynchronous motor with VDF 0-10V ? ) ? Do you want to switch from speed mode to angular mode ( a bit like ORIENT does ) ?
Last edit: 02 May 2023 11:34 by jpg.
Time to create page: 0.336 seconds
