Probe Basic 2.9 or 2.10 install
13 Dec 2022 01:17 #259284
by COlger81
Probe Basic 2.9 or 2.10 install was created by COlger81
Can someone walk me through an install of the most current Probe Basic GUI? I have made multiple failing attempts. Is this GUI abandoned?
Chris
Chris
13 Dec 2022 01:31 #259285
Replied by rodw on topic Probe Basic 2.9 or 2.10 install
Install Bullseye XFCE
and run this script. Its been updated this week to account for the branching off of V 2.9 from master branch (2.10)
github.com/joco-nz/lcnc-bullseye-installer
The following user(s) said Thank You: COlger81, FCS Industrial
13 Dec 2022 14:04 - 13 Dec 2022 17:04 #259313
by COlger81
Replied by COlger81 on topic Probe Basic 2.9 or 2.10 install
Thank you. Successfully running the sim on debain 11 and LCNC 2.10
For anyone else using this method the script has an error and wouldn't install
Linuxcnc-uspace-dev. Fix below;
(After successful install completion, run the commands below to add "Linuxcnc-uspace-dev")
Run In terminal:
cd ~/dev/linuxcnc/
sudo -A dpkg -i linuxcnc-uspace-dev_2.10.0~pre0_amd64.deb
Run In terminal:
cd ~/dev/linuxcnc/
Last edit: 13 Dec 2022 17:04 by COlger81. Reason: Better explanation
- IronManDylan
- Thank you received: 19
05 Aug 2023 19:17 - 05 Aug 2023 19:34 #277041
by IronManDylan
Replied by IronManDylan on topic Probe Basic 2.9 or 2.10 install
I tried following this and everything completed successfully (except for that last line of code you provided COlger81, it threw up an error telling me to SUDO_ASKPASS), but I don't see Probe Basic GUI anywhere. Is the Probe GUI supposed to be available under "my configurations" when launching LCNC?
edit: I have bookworm, not bullseye
Last edit: 05 Aug 2023 19:34 by IronManDylan.
Time to create page: 0.235 seconds
