Question: P value with MESA Setup without encoders
03 Apr 2023 15:02 #268180
by 5G-antry
Replied by 5G-antry on topic Question: P value with MESA Setup without encoders
Thank you. Will look into it
05 Apr 2023 19:58 #268350
by 5G-antry
Currently I can't get LinuxCNC to start yet, with the communication delayed by 1.5ms. If I set the delay when LinuxCNC already started, the machine runs and works (so far tested for 1h).
One brief question. The influential parameters after reading hm2_eth manual and hostmot2 manual are the following?
HAL:
Thank you in advance, always appreciate your help!
HAL:
- hm2_7i76e.0.packet-read-timeout xx % or XXX.XXX ns (dependent on Servo Period)
- hm2_7i76e.0.watchdog.timeout_ns X.XXX.XXX ns
- SERVO_PERIOD = X.XXX.XXX ns
05 Apr 2023 22:27 #268357
Replied by PCW on topic Question: P value with MESA Setup without encoders
It may be that there are timeouts in the card initialization section
of the driver that would need to be lengthened to solve this issue
06 Apr 2023 05:51 #268388
by 5G-antry
Yes, should be a problem of the initialization.
Those are not adaptable by the hm2_eth or hostmot2, if I get it right.
So the first idea with the code adjustment of the firmware (probably hm2_eth.c) could be the way to go?
06 Apr 2023 15:39 #268438
Yes, the timeouts would be in the driver code
The following user(s) said Thank You: 5G-antry
09 Apr 2023 21:57 #268717
by 5G-antry
Ok Thank you.
Are there instructions or a tutorial regarding the creation of flashable bit-files.
I could not find sth in the git.
My plan would be to adapt the C-Code (that causes the timeouts), create a new bit file with all information needed for the Mesa 7i76E and flash it
... And hopefully do not brick the Mesa card
Maybe I will create a new thread.
By now this thread is rather off-topic
09 Apr 2023 22:01 - 09 Apr 2023 22:02 #268718
The timeout code is in hm2_eth the driver (part of LinuxCNC)
there are no timeouts in the 7I76E firmware (other than the
settable watchdog timeout)
Last edit: 09 Apr 2023 22:02 by PCW.
09 Apr 2023 22:04 #268719
by 5G-antry
Ok.
Now I got it.
Had a understanding issue what is part of Mesa code and Driver code
Now I got it.
Time to create page: 0.813 seconds
