Mesa 7i96s PWM outputs
16 Apr 2023 07:59 #269199
by mwidlok
Replied by mwidlok on topic Mesa 7i96s PWM outputs
Thank You all for Yours help.
Using wiki wiki.linuxcnc.org/cgi-bin/wiki.pl?Editing_MESA_Bitfiles I managed to create custom bit file for the board. In fact the only changes needed is to use Effinix software and load "seven7i96s.xml" project. Editing vhd files, and making changes to project source is then almost the same.
Bitfile created by PCW, also works nice, however I've decided finally to use my own - it removes unused Stepgen modules, and adds direction pin to PWMs. PCW's 7i96s_3pwmd deletes only one stepgen and does not use direction pins for PWMs. In case anyone is interested this is the file:
18 Mar 2024 14:33 #296206
by COFHAL
Replied by COFHAL on topic Mesa 7i96s PWM outputs
I need a custom firmware for the 7i76 table to control 3 DC servos with +- 10 volts. This requires replacing 3 Stepgens, with PWM-DIR output. Peter could help me.
- Thank you received: 5934
18 Mar 2024 17:23 #296230
2. Why are you asking for 7i76 firmware on a 7i96S topic that is not even in the "driver boards" section?
So for 1 you would need some hardware to change from PWM to +-10V, and this might be easier using some small boards that do step/dir to +-10V
And for 2 start a new topic on the proper section so PCW can see it.
Replied by tommylight on topic Mesa 7i96s PWM outputs
1. 7i76 can not do +-10V no matter what firmware you flash.I need a custom firmware for the 7i76 table to control 3 DC servos with +- 10 volts. This requires replacing 3 Stepgens, with PWM-DIR output. Peter could help me.
18 Mar 2024 17:32 #296231
by COFHAL
Not, problem I have the mesa 7i33A, I need this firmware to generate the PWM and DIR for the 7i33A.
18 Mar 2024 17:35 #296233
Oh, nice!Not, problem I have the mesa 7i33A, I need this firmware to generate the PWM and DIR for the 7i33A.
18 Mar 2024 18:24 #296236
Replied by PCW on topic Mesa 7i96s PWM outputs
What FPGA card do you have?
18 Mar 2024 18:39 #296239
by COFHAL
I have Both.But I also need, in addition to the encoder input, to bring both cards to use the other inputs as inputs for 3 encoders, to be able to have feddback to control the DC servomotors.
18 Mar 2024 19:04 #296241
I'm still not clear on what FPGA cards you have
18 Mar 2024 20:49 #296249
by COFHAL
I have 7i96 and 7i96s Boards
18 Mar 2024 21:10 - 18 Mar 2024 21:11 #296253
Do you need encoders also?
Do you need index inputs on the encoders?
Last edit: 18 Mar 2024 21:11 by PCW.
Time to create page: 0.121 seconds
