Linuxcncrsh reading a hal pin?
18 Apr 2023 07:21 #269356
by blazini36
Linuxcncrsh reading a hal pin? was created by blazini36
I suppose this isn't limited to linuxcncrsh but I need a method of pushing the value out to linuxcncrsh. If I want to set a pin it just looks like:
...to pass a value into an M1xx file. But how do I read the pin value into linuxcncrsh? is it just an echo or something in the mcode file with the mcode file being something like:
I'll be getting help with this from somebody who's more competent then me with this. I just need to know the method of doing it.
set mdi M1xx p123.456
halcmd show pin whatever.whatever
echo something
18 Apr 2023 12:49 #269369
Replied by andypugh on topic Linuxcncrsh reading a hal pin?
I am not sure that it is even possible. Linuxcncrsh is a user interface, and if you look into it, the other user interfaces have no access to HAL pins either.
It is just about possible that you can get back data with
MDI "(DEBUG, #<_hal[parport.0.pin-0-in]>)" which is the G-code access to HAL pins.
What you probably want is halrmt: linuxcnc.org/docs/stable/html/man/man1/halrmt.1.html
The following user(s) said Thank You: blazini36
18 Apr 2023 17:32 #269378
by blazini36
Replied by blazini36 on topic Linuxcncrsh reading a hal pin?
I didn't even realize halrmt was a thing.
I was hoping you'd chime in since you're the resident expert. It looks like halrmt doesn't take gcodes, where linuxcncrsh does and that is what I need.
I'm trying to use openPnP with LinuxCNC as the controller. OpenPnP pipes out gcode typically to a 3d printer style controller over a serial or ethernet port so I'm looking to use linuxcncrsch for this purpose with a local port. OpenPnP uses a "gcodeDriver" which is configurable for however it needs to be so I'm in the middle of setting up the driver for linuxcncrsh. The method of setting hal oins with Mcodes through linuxcncrsh seems fine.
I believe OpenPnP can support multiple gcode drivers/controllers. So it's probably possible that I can use both linuxcncrsh and halrmt, they seem to share the same command/confirm structure. The doc only mentions halrmt being started from the terminal but can it be started from the hal file like linuxcncrsh?
so if I use DISPLAY=linuxcncrsh, then in hal
loadusr halrmt --[otherStuff]
does that work or is there a better way to achieve what I'm trying to do?
18 Apr 2023 17:45 #269379
by blazini36
Not sure how promising this sounds...
lol well I hope it does
Bugs
It is not know if this interface currently works.
18 Apr 2023 20:06 #269383
Sorry, I just know that linuxcnrsh and halrmt exist, I have never used either.
18 Apr 2023 20:18 #269384
by blazini36
Well I suppose I can add that to the list of experiments. Thanks for mentioning it though, I probably would not have found it.
Time to create page: 0.137 seconds
